301 - 320 of 382 Posts
Hello,
I want to install active cruise control (MRCC) for my Mazda CX-3
My car was bought in the USA, I use it in Poland.
Will there be no problem with my cruise control with active cruise control?
I am sending vin number:
JM1DKFC76J1305389
Is anyone able to give part numbers
I don't know if in Europe part numbers have the same order numbers.
Additionally, if I don't have a head up display, do I have to buy it if I want to install active cruise control?
Thank you very much for all the information that will help me install active cruise control.
In my car I have SCBS system, the camera on the windshield looks like the attached picture
Do I have to replace the entire steering wheel or just the buttons on the right?
274850
274852
I did a search, manually...not sure where the search button for the topic is at. I was wondering if this would work with my 14 m6? I do have the pedestrian braking.
Hi guys, thanks for all the information in this thread. I have a 2017 CX-5 GT without Technology Package. It has only the base instrument cluster with black/white screen on the right. Does the MRCC retrofit require the instrument cluster with the color screen on the right? Thanks
No.
I dont know about your car, but mine shows a different icon that turns green when its engaged and also displays on the HUD.
Yes that's exactly my worry. Without HUD, it won't display MRCC settings. I believe I need to retrofit the multi-display instrument cluster type "A".
274900
I'm adjusting codes in my 2017 CX-5 for MRCC retrofit. After comparing data of 3 CX5's, I noticed 720-04-16 B0 should be changed from 40 to 44 and 720-04-19 B0 changed from "00" to "C0" as it relates to Lane keep assist.
Hope this helps!
Hope this helps!
720-04-16 related to SBCS-R.
Yes it does, but in my case all 3 vehicles were already equipped with SBCS. But only the 2 that were originally equipped with MRCC had 44 on 720-04-16 B0. So it must be something on Bit 2 because when changed to "1", B0 becomes "44"
Because some model came with SCBS-F only, i'm sure it related to SCBS-R, not for MRCC.
luyenok is right. I have a CX-5 2016 without MRCC. From factory only SCBS-F was activated. I activated SCBS-R and changed 720-04-16 B2 to 44 for that:
720-04-01: original 1A09 0080 FFCE to new 1A29 0080 FFEE
720-04-16: orginal 8000 2400 06EB to new 8000 4400 060B
I just finished the MRCC retrofit, including instrument cluster swap to type A. I have only 2 FSC codes U2100 - initial configuration not complete and B115E - Camera module - missing calibration. Do I need to perform Relearn for FSC, as I did for ABS?
No need to relearn FSC on my car (CX5 2017), just do it for ABS and SBS, but you can make a try to clear all errors.
