1 - 2 of 2 Posts
2007 mazdaspeed 3 with cat delete manzo downpipe, intake and hypertech tuner. I found an exhaust leak around the turbo to downpipe gasket and it's only getting 14psi of boost, could this be the reason that it's running lean and having a boost issue? All the vacuum lines and tight and in good shape.
Silver Surfer
You should fix the connection from the turbo to the downpipe. I believe a leak that close to the turbo will make your car run pretty badly.
1 - 2 of 2 Posts
