1 - 20 of 303 Posts
283205
MAZDA HOME SCREEN for .up FIRMWARE SHOWN ABOVE
TAKE DOWN NOTICE FOR SERVER ACTIVATED BY Mega..
I WILL NO LONGER BE OFFERING A SERVER, PLZ DO NOT ASK FOR INFO PRIVATELY.
All too hard in 2021.
These Details are for Genuine Mazda Factory Install of Car Play + Android Auto plus
current Updated Firmware, see link in Sig for all latest download Firmware for updates with or without CP/AA and instructions to manually install them.
YES, you MUST Install correct 70's Firmware FIRST for your Region and Run/Use it in your car for as long as you like.
REGIONS..for FIRMWARE Download
4A N (ADR)
is for Australia-NZ, Asia (except Japan +China), Middle East, Brazil, Pacific O
EU N is for Europe and UK
NA N is for North America, USA, Canada, Mexico.
NOTE: AFTER 70's Firmware install and in use You Will Not see any information about CP/AA UNTIL and AFTER you install (fit) the TWO Genuine Mazda Parts LAST, you will then see the working CP/AA User Interface (UI).
Make sure your 'Android Auto' Phone App is also the very latest available too.
Only use a Genuine or Quality Phone Power Lead/Cable that came with Phone between the Phone Port and new 'AUX Hub'.
YES, you MUST Purchase the Two Genuine Mazda Parts and then Fit them LAST.
ALL the information on what to do is in the PDF in my Signature Below.
This Thread is NOT for Tweaks or ANY other cheap way to install CP/AA (which does not work anyway and will end up costing you more $$s).
NOTE:
You can not rename File whatsoever.
You can not have ANY other file or files or folders on your flash drive.
You must only have the correct .up file(s) on a small FAT32 (about 16GB) Flash Drive, file CAN NOT be in a .zip or .rar format.
IF still having issues of CMU not seeing USB Flash Drive do a full format clean of Drive.
Put small <16GB USB Drive in Windows 10 PC, go to Start, This PC, RIGHT Click on the Drive, Select Format.., Select FAT32, Select Start, click OK, all files on Drive will be Deleted and Drive Re-Formatted (cleaned).
Copy/Paste new Firmware file(s) ONLY on Drive, remove from PC and try in your car again.
IF you are using any MacOS PC to download file then that will also corrupt your Flash Drive as Macs add hidden files onto flash drive and car CMU will not see the file.
MAZDA ONLY supports MS-Intel Windows 10 64bit OS and is used by all car makers for Diagnostic and Maintenance UPDATES in their Automobiles.
Apple (Mac) systems is not supported or used by any car brands in Service Departments or for Diagnostics, period.
WIRELESS Carplay is ONLY INCLUDED WITH 74.00.230A FIRMWARE for your region which is also a normal Update progression from the now outdated 70.00.367A...as of today (May 10, 2021) 74.00.230A is only available for NA N.
HOWEVER one Must Also Purchase a New CMU from a 2021 Model for a Wireless CP spec car and CMU as not ALL 2021 Models come standard from factory with WCP CMU.
WIRELESS CARPLAY WILL NOT WORK ALONE WITHOUT 74 Firmware and NEW 2021 CMU (meant for WCP), as far as I know those TWO things are all that are required, the Firmware is Free and New WCP CMU is about $900 USD.
282163
Suppliers for WIRED CP/AA Parts (Not about WCP)
USA- Worldwide
US
EU-DE
AUSTRALIA
Discussion Starter · #2 · (Edited)
REGION CODES,.
for Mazda MZD CONNECT.
NA N
is...
Region NORTH AMERICA -
USA, Canada, Mexico, Puerto Rico, known as 'NA N' on your Touchscreen.
EU N is...
Region EUROPE -
Albania, Andorra, Austria, Belarus, Belgium, Bosnia, Bosnia Herzegovina, Bulgaria, Croatia, Czech, Denmark, Estonia, Finland, France, Germany, Gibraltar, Greece, Hungary, Ireland, Israel, Italy, Kazakhstan, Kosovo, Latvia, Liechtenstein, Lithuania, Luxembourg, Macedonia, Malta, Moldova, Monaco, Montenegro, Netherlands, Norway, Portugal, Poland, Romania, Russia, San Marino, Serbia, Slovakia, Slovenia, Spain, Sweden, Switzerland, Turkey, Ukraine, United Kingdom, Vatican, known as 'EU N' on your Touchscreen.
4A N is...
Region ADR -
Australia, Christmas Island, Fiji, Indonesia, Kangaroo Island, Malaysia, M-East, New Zealand, Oceania, Papua New Guinea, Philippines, Qatar, Saudi, Singapore, South Africa/Africa, South America (Most of), Asia (Not Japan or China), Tasmania, Thailand,
known as '4A N' on your Touchscreen.
To Find plus Firmware Number..
In most cases go to touchscreen 'SETTINGS',
Far Right Folder 'SYSTEM',
Down to 'ABOUT'
Then 'Version Information'.
MAZDA Firmware ALERT
from AUG 09, 2021
MAZDA (MZD) CONNECT, WHAT FIRMWARE DO I INSTALL..?
FOLLOW the ''Failsafe+Reinstall 2 FILE Install Procedure''.Pdf 100%.
for THE 2 File update process in No1 and or No2.
FOLLOW the ''Update.up FILE Install Procedure''.Pdf 100%
for THE 1 'update.up' in No3....below.
'.up' Firmware used for All MAZDA-MZD CONNECT MODELS 2014-2021.
NOT For first production CX-5 or Mazda 6 with TomTom Navigation.
NOT For MAZDA CX-30 or MX-30 or MAZDA 3 (BP).
*NOT For 2021~ MAZDA CX-5 (KF) or MAZDA CX-9 (TC) *.
BEFORE you START, Switch CAR OFF,
Then Remove Navigation 'SD Card' and
LEAVE the SD Card OUT of the Car until
the FINAL File is Installed.
Then Car OFF again, then Insert SD Card.
Then start car.
Navigation will work as normal when using CONNECT.
# 1. Your FIRST Install Procedure,
THIS # 1 Install ONLY APPLIES to BM MAZDA 3s ONLY..!
All Sold New before March 2016 (approx) that has Not
Already been Updated to a later (or newer) cmu150 version.
For ALL other Mazda Models go DIRECTLY to (# 2.) BELOW # 1.
IF Your BM Mazda 3 has old Firmware ON or BELOW 30.00.895A
LIKE 24.00.000 or 25.00.150 or 28.00.300 or 29.00.100C or 30.00.300
THEN YOU MUST UPDATE with Version Number 31.00.100A First!.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
31.00.100A-FAILSAFE.UP (First)
Then next Install
31.00.100A-REINSTALL.UP (Last)
Warning...!!!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL RUN YOUR ''CONNECT'' IN CAR FOR A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE NEXT VERSION TO INSTALL.
Next you MUST do # 2. below
# 2. Your NEXT Install Procedure...
(All Mazda Models with .up Firmware use)
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW 59.00.560A
LIKE 31.00.100A or 41.00.000 or 51.00.351 or
55.00.650 or 56.00.513 or 59.00.502A
THEN YOU MUST UPDATE with Version Number 70.00.100A FIRST.
70.00.100A-FAILSAFE.UP (First)
Then Install
70.00.100A-REINSTALL.UP (Last)
Warning...!!!
THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION TO INSTALL.
Next you MUST do final and last # 3. below
# 3. Your FINAL Install Procedure is now Only a 1 (one) File Install...
Use the ''Update.up FILE Install Procedure''.Pdf instructions.
IF YOUR MAZDA HAS FIRMWARE VERSION ON or ABOVE 70.00.021A
LIKE 70.00.100A or 70.00.110 or or 70.00.150A or 70.00.335C or 70.00.367A
THEN YOU UPDATE to 74.00.230A for the LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY,
MUST USE EITHER ONE of...
NA N_74.00.230A-UPDATE.UP (North America ONLY)
or
EU N_70.00.367A-UPDATE.UP (Europe/UK)
or
4A N_70.00.367A-UPDATE.UP (ADR, AU. NZ, ME, Asia)
THIS IS THE LATEST FIRMWARE CURRENTLY AVAILABLE.
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
More Information on How to get CP/AA Working Do the Following..
OPEN THE ''CARPLAY-AA'' FOLDER IN THIS SERVER
ON HOW TO DO THE GENUINE CONVERSION.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...None, DO NOT ASK.
YOU MUST PURCHASE and INSTALL the TWO GENUINE MAZDA PARTS LAST.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
WCP or Wireless Car Play is included in all 74.00.xxxx Firmware, BUT
You MUST aslo use a new special 2021~
CMU meant for the WCP use, price is around $999 USD.
If 74.00.230A is not in this Server for your Region it means a copy
is not yet available for Your Region or Country out in the wild, yet.
Maybe I'm missing something here, but for the download link in the PDF, the folder with the 7.0 software has only one file and seems to be missing the failsafe?
EDIT: Nevermind, I see that with the most recent version, the failsafe install process is gone.
yes one file ONLY as page 2 of pdf says :)
NEW Firmware out 2021
Old 70.00.367A_update.up
New 74.00.230A_update.up
To see or keep this thread active as it is Not Pinned by mods, (but they still keep PIN Threads that say CarPlay is Coming Soon and is full of 45+ pages of miss information).
I suggest you Bookmark or Add to Favorites in your own Browser.
NLA
Reactions: gazzmanzx6
Discussion Starter · #7 · (Edited)
NLA
Reactions: Tristan-cx5
I've got a 2018 Maz 3 Neo with 59.00.540 4A N , can I go straight to the latest 70.00.352B , or is there an intermediate step ? Apologies , total newbie to Maz 3's , but plenty of PC experience , Thanx
If I am on 55.00753 NA N, I believe I need to update to 70.00.100A then update to 335C version, right? In that case, the sequence of installation should be 70.00.100A fail-safe package -> 70.00.100A re-installation package -> restart -> then repeat process for 70.00.335 update (single file), right?
Can I put all 3 files in a formatted USB drive at the same time? Or should I put in 70.00.100A files first, install those, reformat the USB to put in the 70.00.335 update file?
Thanks in advance.
Process-Question-Answer: Right.
Correct, Mazda recommends to install 70.00.100 NA first, if you are below 56.00.650 NA.
Yes, all files could be copied to one usb stick at the same time.
But why take .335 and not .352 or .367 NA firmware? They are newer and most probably more bugs got fixed.
Just as info: At .367 serial access ID7v2 for AIO tweaks is not possible anymore.
Discussion Starter · #15 · (Edited)
NLA
Thank you for your reply! I was able to install 70.00.100 failsafe and reinstallation then 70.00.367 as you suggested.
I would appreciate it if you could answer some basic questions:
1. Now that I have 70.00.367 NA N (I am in North America) installed, I should be able to install the Mazda Apple CP/AA retrofit kit 00008FZ34 and CarPlay should be on it, right? I just want to make sure I am not missing any steps.
2. I have 2016 Mazda 3 i Sport 4 door sedan - my axillary box is in front of the automatic shifter knob. I am aware that I can drill out the tabs or break the tabs from the various angles to get that box out, but what would be the correct way to do it without breaking anything?
Thanks so much in advance!
1. Yes & Yes.
2. Other way: Disassemble/uninstall the console/front console. See the signature of ASH8 (above) for a link to more details about retrofitting AA/CP. And in this link you can find a lot of trim removal PDFs and Videos for retrofitting AA/CP: HiDrive
Does anyone have any tips on installing the Mazda 3 Automatic gear knob back on? I was able to take it off without any problem but unable to put the knob back on. I put the metal clip back in there to secure the knob to the shifter, placed the plastic button, and I thought I just had to push the button back into the knob but I am unable to push the button back in. I am not sure what I am doing wrong.
Any help please? Can’t drive the car like this, haha
1. Yes & Yes.
Tristan, how did you manage to install the auto shifter knob back in? I put everything back but I am unable to push the button back in because of interference shown in the diagram below... the plastic arm that is supposed to be below like shown in the picture is pulled out above and is unable to be reduced under...
thanks for your input
278484
278485
Edited:
I put the cap on the white thing which stands out and push it in hard/with force or use a screwdriver to push the top white thing down/in. In my CX-5 it looks a little different I think, that`s why you might have the problem. I do not have any info about how to do it at Mazda 3, sorry. Perhaps someone else can help.
And here at the trim removal PDFs of the Mazda 3 (Link) it looks to be the same as at the CX-5, but according to your photo, it is not the same, if you compare it to my photos of the CX-5.
1 - 20 of 303 Posts
