501 - 520 of 558 Posts
2021 Mazda 3 Premium Plus Turbo AWD Hatchback
Anyone else having issues with hidrive? Granted I've never used the site before, so this may be my fault, but the link from ASH8's signature takes me to a 404 page.
Hidrive is fine but yeah, Hidrive is saying the storage is no longer there.
Discussion Starter · #503 ·
Well looks like this is the end..
I cant log in to server either..
Looks like the guy who was paying has no longer renewed his subscription.
I have tried to contact but not looking good.
Oh no!!! Was about to download the 12001… looks like I am a little late😂
Hope someone has a hosting solution they can offer up. Can something like, Mega.nz work?
Mazda 3 2019
Yes it‘s the same for me. I don‘t know, maybe ASH8 got too annoyed of some dumb questions here, so he deleted the files? 🙈
I hope not and it‘s just a temporal problem.
CX 5 2016 2.0i
if anyone has downloaded the old files would they upload them somewhere? If they send them to me, I would upload them to my google hard drive
CX 5 2016 2.0i
Can it be updated from version 59.00.502 NA, directly to the latest version, without installing the other updates? Thanks.
:unsure:
Discussion Starter · #512 ·
These details are from MAZDA, I do not make it up,
WHY cant you Translate and Read..??
It is in new Server.
IF YOUR CAR IS ON 59.00.502, then No. 2 and No 3
APPLIES TO YOUR CAR..!
** MAZDA Firmware ALERT ***
from JUN 01, 2021
MAZDA (MZD) CONNECT, WHAT FIRMWARE DO I INSTALL..?
FOLLOW the 2 different .PDF INSTALL INSTRUCTIONS 100%.
'.up' Firmware used for All MAZDA-MZD CONNECT MODELS 2014-2021.
NOT For first production CX-5 or Mazda 6 with TomTom Navigation.
NOT For MAZDA CX-30 or MX-30 or MAZDA 3 (BP)
*NOT For 2021~ MAZDA CX-5 (KF) or MAZDA CX-9 (TC) *.
BEFORE you START, Switch CAR OFF,
Then Remove Navigation 'SD Card' and
LEAVE the SD Card OUT of the Car until
the FINAL File is Installed.
Then Car OFF again, then Insert SD Card.
Then start car.
Navigation will work as normal when using CONNECT.
1. Your FIRST Install Procedure...
IF YOUR MAZDA has old FIRMWARE VERSION ON or BELOW 30.00.000
LIKE 23.00.000 or 25.00.150 or 28.00.300 or 29.00.100C
THEN YOU MUST UPDATE with Version Number 31.00.100A FIRST.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
31.00.100A-FAILSAFE.UP (First)
Then next Install
31.00.100A-REINSTALL.UP
Warning...!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL RUN YOUR ''CONNECT'' IN CAR FOR
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE NEXT VERSION
TO INSTALL.
2. Your NEXT Install Procedure...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW 59.00.560A
LIKE 31.00.100A or 41.00.000 or 51.00.351 or
55.00.650 or 56.00.513 or 59.00.502A
THEN YOU MUST UPDATE with Verion Number 70.00.100A FIRST.
70.00.100A-FAILSAFE.UP (First)
Then Install
70.00.100A-REINSTALL.UP
Warning...!
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION
TO INSTALL.
3. Your FINAL Install Procedure is ONLY 1 (one) File now...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or ABOVE 70.00.021A
LIKE 70.00.100A or 70.00.110 or or 70.00.150A or 70.00.335C or 70.00.367A
THEN YOU UPDATE to 74.00.230A for the LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY, MUST USE EITHER ONE of...
NA N_74.00.230A-UPDATE.UP (North America ONLY)
or
EU N_70.00.367A-UPDATE.UP (Europe/UK)
or
4A N_70.00.367A-UPDATE.UP (ADR, AU. NZ, ME, Asia)
THIS IS THE LATEST FIRMWARE CURRENTLY AVAILABLE.
INSTALLATION AS PER INSTRUCTIONS IN SERVER
''MAZDA FIRMWARE UPDATE PROCEDURE WORLDWIDE'' .Pdf
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
More Information on How to get CP/AA Working Do the Following..
OPEN THE ''CARPLAY-ANDROIDAUTO INSTALL'' FOLDER IN
THIS SERVER ON HOW TO DO THE GENUINE CONVERSION.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...NONE, SO DO NOT ASK.
YOU MUST PURCHASE AND INSTALL THE TWO GENUINE MAZDA PARTS LAST.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
PACKAGE AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
WCP or Wireless Car Play is included in all 74.00.xxxx Firmware, BUT
You MUST aslo use a new 2021~ CMU meant for WCP use price is over $999 USD.
If 74.00.230A is not in this Server for your Region it means a copy is not yet available
for Your Region or Country in the wild, yet.
:unsure:
@joro010 what is "it" referring to? Are you talking about your fw? Or any particular fw?
Further background information:
If fw59.00.502 and you have an 7"-8" screen and wanted to update to the latest fw74.00.230 for mazda AA/CP subjected that you had the fitted new mazda hub+cables afterward. The user experience for AA/CP will be unpleasant due to the dpi software hardcoded set incorrectly on fw74. What it means is all icons, AA nav bar, notifications etc has been enlarged 20%-30%. Fw70.00.xxx to fw70.00.367 is set naturally which do not appear hideous.
Mazda 3 2019
Thanks a lot ASH8 for transfering the files to a new server and all the explanations. Your work is really appreciated. ☺👍🏻
CX 5 2016 2.0i
If fw59.00.502 and you have an 7"-8" screen and updating to the latest fw (74.00.230 suitable for 2021 cmu and 10" screen) for mazda AA/CP is not wise due to upscaled dpi. If you have no intention to install aio tweaks best would be fw70.00.367, else fw70.00.352 update pdf, follow id7v2 serial access method and how to install aio tweaks with Mazda AA/CP hardware.
[/ QUOTE]
Hello, the car is CX 5 2016, the idea is to upgrade my version with a new one, the last one that allows tweaks is 70.00.100A? Can it be skipped from 59.00.502 to 70.00.100A DIRECTLY? thanks!
@joro010
yes, you can upgrade from fw59.00.502 (id7 previously unlocked for full root access)straight to fw70.00.100A no problem, and definitely retain id7 root access. Higher than Fw70.00.100 will required id7v2 procedure which only works for fw70.00.335-fw70.00.352.
CX 5 2016 2.0i
@joro010
Thank you. This is the best forum! 🔝 🚗
This comment is a bit confusing. I have a NA 2020 CX-5 (non 10" display), currently at 70.00.335, which was factory installed. Can I take this to 74.00.230 without changing the display or CMU? Do I just need the cmu150_NA_74.00.230S_update.up file?
Discussion Starter · #520 ·
CLEARLY YOU do not know what you are talking about!
74.00.230 IS NOT FOR 2021 CX-5 with 10 inch screen.
THIS THREAD IS NOT ABOUT TWEAKS...
You are the only one who is not WISE.
joro, the information I last posted is correct if you want STANDARD FACTOTY Update to LATEST FIRMWARE AVAILABLE from 59.00.502
