1 - 20 of 637 Posts
283287
TAKE DOWN NOTICE FOR SERVER ACTIVATED BY Mega..
I WILL NO LONGER BE OFFERING A SERVER, PLZ DO NOT ASK FOR INFO PRIVATELY.
All too hard in 2021.
HOME SCREEN for .kwi FIRMWARE SHOWN ABOVE
CONNECT UPDATE FIRMWARE
NEXT Generation (2019~) Genuine Mazda CONNECT Firmware is here.
4A0 is for ADR or Australia-NZ, Asia (except Japan +China), Middle East, Brazil, Pacific O
EU0 is for Europe and UK
NA0 is for North America, USA, Canada, Mexico.
CONNECT
The SINGLE File are ONLY for Mazda 3 (BP) and Mazda CX-30 (DM) and MX-30 (DR) also specific 2021~ CX-5 and CX-9, see the MUST READ WARNING.txt in server.
Can Not
be used in the Original Mazda/MZD Connect of 2014-20xx.
NOTE:
You can not rename File whatsoever.
You can not have ANY other file or files or folders on your flash drive.
You must only have the correct ONE single .kwi file on a small FAT32 (about 16GB) Flash Drive, file CAN NOT be in a .zip or .rar format... ONLY a .kwi format.
IF still having issues of CMU not seeing USB Flash Drive do a full format clean of Drive.
Put small <16GB USB Drive in Windows 10 PC, go to Start, This PC, RIGHT Click on the Drive, Select Format.., Select FAT32, Select Start, click OK, all files on Drive will be Deleted and Drive Re-Formatted (cleaned).
Copy/Paste new Firmware file ONLY on Drive, remove from PC and try in your car again.
IF you are using any MacOS PC to download file then that will also corrupt your Flash Drive as Macs add hidden files onto flash drive and car CMU will not see the file.
MAZDA ONLY supports MS-Intel Windows 10 64bit OS and is used by all car makers for Diagnostic and Maintenance UPDATES in their Automobiles.
Apple (Mac) systems is not supported or used by any car brands in Service Departments or for Diagnostics, period.
CMU_7000C0A-NA01_12002.kwi * NON Turbo Engine.
CMU_7000C0A-NA03_1XXXX.kwi * 2021~ CX-5+ CX-9
CMU_7000C0A-NA04_12002.kwi * TURBO ENGINE MZ3 + CX-30
CMU_7000C0A-EU01_10049.kwi*
CMU_7000C0A-EU02_1XXXX.kwi* MX-30 Only
CMU_7000C0A-4A01_10049.kwi (USE EU01 on early 2019)
The NA01 file is for North America ONLY and is < 856MB in size.
The EU01 file is for Europe and is < 706MB in size.
NOTE: File Versions Above are ONLY for all new Mazda 3 (BP) and CX-30 (DM), MX-30 (DR), 2021~ CX-5 (KF) and CX-9 (TC) with same Home Screen Pictured Above.
ONLY Use Correct Firmware for your Region and Car Model and or Engine.
OFFICIAL UPDATE INSTRUCTIONS 3rd post
If your MAZDA has a Higher Package Number right now (which means a later Firmware version) CAN NOT INSTALL ANY OLD or OUTDATED VERSIONS as You can't downgrade in error.
Right Click STANDARD Download the Main File (.kwi) and other information .pdf and .txt as a ONE File at a time.
CHECK .kwi File Integrity with checking it’s Checksum Value.
MUST ONLY be correct .kwi File on your small FAT32 Flash Drive to update in car.
NEWS: On page 20 of this thread (my Browser) is a long list of FAQs for latest ''MAZDA CONNECTED SERVICES'' and explanation in regard to the MyMazda App
version 6.0.0 or higher for your Phone, INCLUDING REMOTE STARTING OF CAR (for Auto Trans Models Only)...MODEL MUST HAVE FACTORY DELIVERED TCU and Mobile Data Access through your Telco, not for all Models or all Countries.
REGION CODES,.
for new Mazda CONNECT Only.
NA0*
is...
Region NORTH AMERICA -
USA, Canada, Mexico, Puerto Rico.
EU0* is...
Region EUROPE -
Albania, Andorra, Austria, Belarus, Belgium, Bosnia, Bosnia Herzegovina, Bulgaria, Croatia, Czech, Denmark, Estonia, Finland, France, Germany, Gibraltar, Greece, Hungary, Ireland, Israel, Italy, Kazakhstan, Kosovo, Latvia, Liechtenstein, Lithuania, Luxembourg, Macedonia, Malta, Moldova, Monaco, Montenegro, Netherlands, Norway, Portugal, Poland, Romania, Russia, San Marino, Serbia, Slovakia, Slovenia, Spain, Sweden, Switzerland, Turkey, Ukraine, United Kingdom, Vatican.
4A0* is...
Region ADR -
Australia, Christmas Island, Fiji, Indonesia, Kangaroo Island, Malaysia, M-East, New Zealand, Oceania, Papua New Guinea, Philippines, Qatar, Saudi, Singapore, South Africa/Africa, South America (Most of), Asia (Not Japan or China), Tasmania, Thailand.
* NOTE is also MODEL and Or ENGINE Type Specific.
01 is for Non Turbo Engine.
02 is for MX-30.plus is OTA where applicable.
03 is for 2021~ CX-5 + CX-9.
04 is for TURBO Engine Mazda 3 + CX-30.
To VERIFY your Existing in car Firmware ''Number'' or Package #.
Go to home screen 'SETTINGS',
Then 'SYSTEM SETTINGS',
Next 'SYSTEM INFORMATION',
Then 'VERSION INFORMATION'
See Package: 12345 (example).
What version do I INSTALL?
Check your cars Connect Screen FIRST to see which
Version Number is in your car right Now.
(see Connect II Update .PDF).
DO NOT INSTALL a Lower Version Numbered Firmware
IF your new car already has a higher number
version File number than what is available in server.
Choose either 1 below ONLY.
**01 Firmware for all NON Turbo Engine cars ONLY.
**02 Firmware for MX-30 ONLY. also OTA.
**03 Firmware is for 2021~ CX-5 + CX-9 10 inch Widescreen ONLY.
**04 Firmware for Mazda 3 + CX-30 Turbo ONLY.
Do NOT install ANY OTHER VERSION (01,02,03,04)
even if others ARE LISTED HERE that maybe
a Higher or Later iteration Version Number than
the current available here meant for YOUR Cars
region and engine and or model right now.
NOTE:
4A0* (ADR) Some early 2019 OWNERS can install EU0* Firmware.
If your Mazda is Brand NEW and already has a
Higher or a Later iteration Number than LISTED
here then there are No Updates Available Yet.
Discussion Starter · #8 · (Edited)
When you say “BP Mazda 3” what is the BP !?
BP is the MODEL CODE of the car...and is part of the cars VIN (Number).
Mazda worldwide uses this 'code' to itentify what model, Parts Departments also.
The old model Mazda 3 was the BM and BN.
One before that Mazda 3 was BL.
Mazda 2 is a DJ and DL
CX-3 is DK.
Some trivia, car makers don't usually use the O (letter) as in computers/data O letter gets mistaken for number 0, Same applies to letter I (i) as it can be mistaken as a 1.
Discussion Starter · #9 · (Edited)
I’m little bit scared about update my infotainment system. I don’t know if is the right file for Canadian version ...
What is the file in the car now, seriously Read what is says.
IF your FIRMWARE is a Lower Number then it is outdated, and up to you if you update at your own risk.
IF your Firmware is the EXACT SAME Number then you don't update...no reason to.
IF your Firmware Number is Higher than listed ABOVE then YOU DO NOT UPDATE...
Pretty simple really.
Changelogs are not available at the moment, same applies to fix bugs like ANY Firmware Update.
If anyone does not understand this then they should not touch their car.:nerd:
Thanks for the last message :) the update change nothing visible at this moment. The annoying voice on the GT is still there :( I check my VIN number before and it’s ok :)
I talk with Mazda about the voice when opening this door and the guy tell me that Mazda works with Panasonic at this moment for this problem
Discussion Starter · #11 · (Edited)
OFFICIAL Update Procedure is now in Server...and YES it will be the same worldwide see LINK 1st Post.
Reactions: Josey
Discussion Starter · #15 ·
Please tell me how to unzip this file(.kwi).
HUH...
WHY do you ask about unzip file?
DID you Combine all at once to download, YOU SHOULD download, 1 (one) file at a time.
IF your file is a .zip, you need to extract it with Winzip or other program, or download the .kwi file ONLY again, one file at a time.
ONLY .kwi on Flash Drive.
Check Hashsum.
Did you ever use the navigation system? The voice stopped telling me the speed limit once I used it
Thanks for the last message <img src="http://mazda3revolution.com/forums/images/smilies/smile.gif" border="0" alt="" title="Smiley" class="inlineimg" /> the update change nothing visible at this moment. The annoying voice on the GT is still there <img src="http://mazda3revolution.com/forums/images/smilies/frown.gif" border="0" alt="" title="Sad" class="inlineimg" /> I check my VIN number before and it’️s ok <img src="http://mazda3revolution.com/forums/images/smilies/smile.gif" border="0" alt="" title="Smiley" class="inlineimg" />
You have the GS or GT ? This problem is only certain GT. I’m not using the SD card so the voice is not talking. I’m waiting for Mazda update.
1 - 20 of 637 Posts
