841 - 860 of 888 Posts
Hey Roy,
wrong Thread, this here is for the MZDA Connect II Firmware starting 2019 and up. Why are you searching for these old versions? The newest is 74.00.311A.
You only need the EU-Version. Forget all versions with NA or ADR, JP and CHN
bye
Gruni
Hi Gruni
I want to at tools that are made by devolopers like there one android auto. I can't get it working with the newer versions because i need to change my usb power output by Mazda dealer and they would charge me 400 euros for that. my car is from 2015.
2019 Mazda 3 Premium Sedan
HOME SCREEN for .kwi FIRMWARE SHOWN ABOVE
CONNECT UPDATE FIRMWARE 7th Gen from 2019~ onward,
Message me for your private download link only, Inc your Mazda's Model, Year, your Country.
ALL DETAILS UPDATED BELOW from July 18th, 2022.
File Description example for North America market.
CMU 7000C0A-NA03 11048
  • CMU = Unit
  • 7000C0A-NA03 = Model ID
  • 11048 = Software Version
NEXT Generation (2019 ~) Genuine Mazda CONNECT Firmware is here...
EU** is for Europe, UK, Australia, New Zealand.
NA** is for North America, USA, Canada, Mexico.
4A** is for GENERAL R.H.D - L.H.D, Except Hong Kong and Macau.
HK** is for Hong Kong and Macau.
These SINGLE .kwi File are ONLY for Mazda 3 (BP) and Mazda CX-30 (DM) MX-30 (DR) CX-50 (VA) , CX-60 (KH) also specific 2021~ CX-5 and CX-9.
Can Not
be used in the Original Mazda/MZD Connect of 2014-20xx or 6th Generation model.
NOTE:
You can not rename the downloaded new File whatsoever.
You can not have ANY other file or files or folders on your flash drive to do install.
CX-60~ uses USB 'C' Flash Drive port (Can not use any USB 'A' adapters).
You must only have the correct ONE single .kwi file on a FAT32 ( < 32 GB) Flash Drive, file CAN NOT be in a .zip or .rar format... ONLY in a .kwi format.
IF still having issues of CMU not seeing USB Flash Drive do a full format clean of Drive.
Put a small <16GB USB Drive in Windows 10 PC, go to Start, This PC, RIGHT Click on the Drive, Select Format.., Select FAT32, Select Start, click OK, all files on Drive will be Deleted and Drive Re-Formatted (cleaned).
Copy and Paste new Firmware file ONLY on Drive, remove from PC and try in your car again.
IF you are using any MacOS PC to download file then that will also corrupt your Flash Drive as Macs adds hidden files onto flash drive and car CMU will not see the .kwi file.
MAZDA ONLY supports MS-Intel Windows 10 64bit OS and is used by all car makers for Diagnostic and Maintenance UPDATES in their Automobiles.
Apple (Mac) systems is not supported or used by any car brands in Service Departments or for Diagnostics, period.
CMU_7000C0A-NA01_12002.kwi * NON Turbo Engine. Mazda3 and CX-30 Built BEFORE July 1st 2021.
CMU_7000C0A-NA02_11036.kwi * MX-30 Only.
CMU_7000C0A-NA03_11040.kwi * CX-5 + CX-9 2021 on with 10.25 inch center display.
CMU_7000C0A-NA04_12002.kwi * TURBO ENGINE Mazda3 + CX-30 TURBO Built before July 1st 2021.
CMU_7000C0A-NA05_11014.kwi * CX-50 (VA) North America ONLY.
CMU_7000C0A-NA06_12012.kwi * Mazda3 and CX-30 Turbo Built AFTER July 1st 2021 to present also with TCU (Telematics Communication Unit).
CMU_7000C0A-EU01_11000.kwi * Mazda3 and CX-30.
CMU_7000C0A-EU02_11028.kwi * MX-30 Only.
CMU_7000C0A-EU03_10028.kwi * CX-5 + CX-9 with 10.3 inch center display.
CMU_7000C0A-EU07_14004.kwi * CX-60 (KH).
CMU_7000C0A-4A01_10047.kwi * Only have this version.
CMU_7000C0A-HK01
_1***.kwi Do not have any copies.
The NA** file is for North America ONLY.
The EU** file is for Europe/UK/Australia and New Zealand.
The 4A** file GENERAL R.H.D - L.H.D except Hong Kong and Macau.
The HK** file is for Hong Kong and Macau.
Do this to find out what Version NUMBER is running in your car now..
1. Turn the ignition to ACC or ON.
2. Select ”Settings” on the Home screen.
3. Select “System Setting”.
4. Select “System Information”.
5. Select “Version Information”.
6. See 'System Software': version number eg,10016 or 12001, etc
If your cars NUMBER is Below those for your Country and Car Model shown above then you can UPDATE to a later and better version.
No, I do not have Changelogs for every update change.
YES, I CAN SUPPLY YOU ONE (1) OF THE ABOVE .kwi FILES TO UPDATE YOUR MAZDA CONNECT, BUT IF YOUR CAR MODEL ALREADY HAS A HIGHER NUMBER (11000, 10028, 10047, etc) THEN I CAN NOT HELP YOU AS YOU CAN ONLY INSTALL A HIGHER VERSION THAN WHAT IS ALREADY PRESENT IN YOUR MAZDA.
NOTE THE VERSIONS: LIKE NA01, NA05, EU02, EU03, 4A01, HK01 AS THESE ARE FOR SPECIFIC COUNTRY and REGIONS Only, YOU CAN NOT MIX or CHANGE COUNTRY and MODEL TYPE from your cars ORIGINAL FACTORY INSTALL.
I WILL ONLY REPLY TO A PRIVATE MESSAGE, DO NOT ASK IN THIS THREAD.
I CAN NOT COACH YOU ON HOW TO UPDATE IF YOU DO NOT POSSESS OWN ABILITY TO DO SO...EASY INSTRUCTIONS INCLUDED within DOWNLOAD.
* NOTE:
File Versions Above are ONLY for all new Mazda 3 (BP) and CX-30 (DM), MX-30 (DR), 2021~ CX-5 (KF), CX-9 (TC), CX-50 (VA), CX-60 (KH) with Home Screen Pictured Above.
ONLY Use the Correct Firmware for your Region and Car Model and or Engine Type.
*SEE How To .PDF in POST #3.
If your MAZDA has a Higher Package Number right now (meaning a Newer Firmware Version) THEN YOU CAN NOT INSTALL ANY OLDER or OUTDATED VERSIONS.
NEWS: On page 20 of this thread (my Browser) is a long list of FAQs for latest ''MAZDA CONNECTED SERVICES'' and explanation in regard to the MyMazda App
version 6.0.0 or higher for your Phone, INCLUDING REMOTE STARTING OF CAR (for Auto Trans Models Only)...MODEL MUST HAVE FACTORY DELIVERED TCU and Mobile Data Access through your Telco, not for all Models and or all Countries.
I can’t send you a private message because I’m new to this forum. Hope someone can help me here. Wanting to update to the latest version. Thank you.
Good morning from here ~! I was wondering if i could get the kwi file for the Philippine models. I can't pm yet so i will work on doing that.
But for clarification I used to think we had to use ADR / 4a01 kwi files but it seems the EU01 files should be fine ?
I have package version 10015 installed currently.
Thank you~!
edit: Ah i was looking at the 2019 post, Main post clearly has been updated to state 4a01 files should be used i think
Discussion Starter · #853 ·
NEW MAZDA CONNECT FOR EU.....ONLY.
New Version of Mazda Connect Firmware
7000C0A-EU06 12004.kwi
For MY2022 Mazda CX-30 and Mazda 3 with last 6 digits of VIN starting with 300001~onwards.
SEE PAGE ONE of THIS Thread Post Number #11.
Excellent. Hopefully this means the earlier model will get an update soon
I don't see how a cmu update fixes or adjust lane keep assist. Surely that would be handled by a different module like bcm or vcm
I'm not sure either but what I can confirm is the following:
EU01 car on 11000 - LKA 60KM/h or LOWER
EU06 car on 12004 - LKA 60KM/h or LOWER
EU06 car on 12006 - LKA 60KM/h or HIGHER
Now, it may be a coincidence as the EU06 car may have come, from the factory, newer firmware versions for other modules, like you say.
I don't think we'll ever get conclusive evidence outside of observing the effective differences ourselves, hence my comment above.
