821 - 840 of 888 Posts
Hello. Where can i find the 74.00.311 NA firmware?
See this thread:
HOME SCREEN for .kwi FIRMWARE SHOWN ABOVE
CONNECT UPDATE FIRMWARE 7th Gen from 2019~ onward,
Message me for your private download link only, Inc your Mazda's Model, Year, your Country.
ALL DETAILS UPDATED BELOW from July 18th, 2022.
File Description example for North America market.
CMU 7000C0A-NA03 11048
  • CMU = Unit
  • 7000C0A-NA03 = Model ID
  • 11048 = Software Version
NEXT Generation (2019 ~) Genuine Mazda CONNECT Firmware is here...
EU** is for Europe, UK, Australia, New Zealand.
NA** is for North America, USA, Canada, Mexico.
4A** is for GENERAL R.H.D - L.H.D, Except Hong Kong and Macau.
HK** is for Hong Kong and Macau.
These SINGLE .kwi File are ONLY for Mazda 3 (BP) and Mazda CX-30 (DM) MX-30 (DR) CX-50 (VA) , CX-60 (KH) also specific 2021~ CX-5 and CX-9.
Can Not
be used in the Original Mazda/MZD Connect of 2014-20xx or 6th Generation model.
NOTE:
You can not rename the downloaded new File whatsoever.
You can not have ANY other file or files or folders on your flash drive to do install.
CX-60~ uses USB 'C' Flash Drive port (Can not use any USB 'A' adapters).
You must only have the correct ONE single .kwi file on a FAT32 ( < 32 GB) Flash Drive, file CAN NOT be in a .zip or .rar format... ONLY in a .kwi format.
IF still having issues of CMU not seeing USB Flash Drive do a full format clean of Drive.
Put a small <16GB USB Drive in Windows 10 PC, go to Start, This PC, RIGHT Click on the Drive, Select Format.., Select FAT32, Select Start, click OK, all files on Drive will be Deleted and Drive Re-Formatted (cleaned).
Copy and Paste new Firmware file ONLY on Drive, remove from PC and try in your car again.
IF you are using any MacOS PC to download file then that will also corrupt your Flash Drive as Macs adds hidden files onto flash drive and car CMU will not see the .kwi file.
MAZDA ONLY supports MS-Intel Windows 10 64bit OS and is used by all car makers for Diagnostic and Maintenance UPDATES in their Automobiles.
Apple (Mac) systems is not supported or used by any car brands in Service Departments or for Diagnostics, period.
CMU_7000C0A-NA01_12002.kwi * NON Turbo Engine. Mazda3 and CX-30 Built BEFORE July 1st 2021.
CMU_7000C0A-NA02_11036.kwi * MX-30 Only.
CMU_7000C0A-NA03_11040.kwi * CX-5 + CX-9 2021 on with 10.25 inch center display.
CMU_7000C0A-NA04_12002.kwi * TURBO ENGINE Mazda3 + CX-30 TURBO Built before July 1st 2021.
CMU_7000C0A-NA05_11014.kwi * CX-50 (VA) North America ONLY.
CMU_7000C0A-NA06_12012.kwi * Mazda3 and CX-30 Turbo Built AFTER July 1st 2021 to present also with TCU (Telematics Communication Unit).
CMU_7000C0A-EU01_11000.kwi * Mazda3 and CX-30.
CMU_7000C0A-EU02_11020.kwi * MX-30 Only.
CMU_7000C0A-EU03_10028.kwi * CX-5 + CX-9 with 10.3 inch center display.
CMU_7000C0A-EU07_14004.kwi * CX-60 (KH).
CMU_7000C0A-4A01_10047.kwi * Only have this version.
CMU_7000C0A-HK01
_1***.kwi Do not have any copies.
The NA** file is for North America ONLY.
The EU** file is for Europe/UK/Australia and New Zealand.
The 4A** file GENERAL R.H.D - L.H.D except Hong Kong and Macau.
The HK** file is for Hong Kong and Macau.
Do this to find out what Version NUMBER is running in your car now..
1. Turn the ignition to ACC or ON.
2. Select ”Settings” on the Home screen.
3. Select “System Setting”.
4. Select “System Information”.
5. Select “Version Information”.
6. See 'System Software': version number eg,10016 or 12001, etc
If your cars NUMBER is Below those for your Country and Car Model shown above then you can UPDATE to a later and better version.
No, I do not have Changelogs for every update change.
YES, I CAN SUPPLY YOU ONE (1) OF THE ABOVE .kwi FILES TO UPDATE YOUR MAZDA CONNECT, BUT IF YOUR CAR MODEL ALREADY HAS A HIGHER NUMBER (11000, 10028, 10047, etc) THEN I CAN NOT HELP YOU AS YOU CAN ONLY INSTALL A HIGHER VERSION THAN WHAT IS ALREADY PRESENT IN YOUR MAZDA.
NOTE THE VERSIONS: LIKE NA01, NA05, EU02, EU03, 4A01, HK01 AS THESE ARE FOR SPECIFIC COUNTRY and REGIONS Only, YOU CAN NOT MIX or CHANGE COUNTRY and MODEL TYPE from your cars ORIGINAL FACTORY INSTALL.
I WILL ONLY REPLY TO A PRIVATE MESSAGE, DO NOT ASK IN THIS THREAD.
I CAN NOT COACH YOU ON HOW TO UPDATE IF YOU DO NOT POSSESS OWN ABILITY TO DO SO...EASY INSTRUCTIONS INCLUDED within DOWNLOAD.
* NOTE:
File Versions Above are ONLY for all new Mazda 3 (BP) and CX-30 (DM), MX-30 (DR), 2021~ CX-5 (KF), CX-9 (TC), CX-50 (VA), CX-60 (KH) with Home Screen Pictured Above.
ONLY Use the Correct Firmware for your Region and Car Model and or Engine Type.
*SEE How To .PDF in POST #3.
If your MAZDA has a Higher Package Number right now (meaning a Newer Firmware Version) THEN YOU CAN NOT INSTALL ANY OLDER or OUTDATED VERSIONS.
NEWS: On page 20 of this thread (my Browser) is a long list of FAQs for latest ''MAZDA CONNECTED SERVICES'' and explanation in regard to the MyMazda App
version 6.0.0 or higher for your Phone, INCLUDING REMOTE STARTING OF CAR (for Auto Trans Models Only)...MODEL MUST HAVE FACTORY DELIVERED TCU and Mobile Data Access through your Telco, not for all Models and or all Countries.
Hello can you share me the latest firmware. I have a 2017 CX-5 NA Version 2.0 L
been lurking for a while
son has a 2019 Mazda3. Version 11012.
North America (US)
I downloaded back in May 2022: CM_7000C0A-NA01_12002.kwi With help from this forum ( not this string)
instead of paying dealer for install, I would like to verify this is the correct file for his vehicle
if more information is needed, please let me know
thanks
Hi everyone I have a 2021 BP in Australia with firmware 1100. I have read there is a newer 12006 firmware that has updated CTS to support lane centering at all driving speeds instead of up to 60km/h. Does anyone have this firmware? Thank you
Sorry, where did you read that? That would be a massive improvement to an otherwise kind of useless feature (IMO) if true.
From a forums website for Australians here https://forums.whirlpool.net.au/thread/96r1v109?r=71460734#r71460734
The comment I'll quote below:
"It’s showing system software version 12006.
Just checked the manual with the car and the CTS steering assist section was updated, it doesn’t state any limit on the speed anymore (apart from the fact that it will only follow the car in front under 50km/h). So looks like it was a recent update with the new model years, like the updates they got in Japan:
https://kevinmariyahqnpc.medium.com/2021-mazda-3-officially-debuts-engine-suspension-and-auxiliary-systems-are-fully-upgraded-aab29dd25532
From a forums website for Australians here Mazda 3 (Fourth gen, 2019–) - Mazda - Automotive - Whirlpool Forums
Interesting… mine has NA06_12012 but it definitely still won’t steer above around 60km/h. I hope NA gets this update at some point.
Just updated my NA '19 HB from 11002 to 12002, wanted to say thanks to @ASH8 for all the information in this thread.
Also, having ran a firmware update once on the previous generation (MZD Connect) infotainment for my prior car, this version was significantly easier and faster.
Thanks for sharing all this! Just very use full information.
Does anyone have one of these files for me?
Hopefully one of the newest EU version. Otherwise any version of these would be great!
55.00.650A/753A/760A / 56.00.521A-NA(NA N)
56.00.100A/230A/240B/511A/512A/513C/514A-ADR(4A N)
56.00.100A/210A/230A/511A/512A/513A/513B/513C-EU
56.00.401A/403A-JP / 59.00.445A-JP / 56.00.100A-CHN
58.00.250A-NA(NA N) / 58.00.251A-ADR(4A N)
59.00.326A/330A/342A/442A/443C/449A/450A-ADR(4A N)
59.00.330A/441A/443A/446A/450A-NA(NA N)
59.00.330A/331A/443C/447A/449A-EU
Thanks alot!
Regards from the Netherlands
Roy
Mazda3 04/2017 BN 120 HP Sports-Line
Thanks alot!
Roy
Hey Roy,
wrong Thread, this here is for the MZDA Connect II Firmware starting 2019 and up. Why are you searching for these old versions? The newest is 74.00.311A.
You only need the EU-Version. Forget all versions with NA or ADR, JP and CHN
bye
Gruni
