leave the car closed for 15 minutesleave the closed for 15 minutes
then you come back and it works.
Thanks, phew. Yea came back to try it 30 mins later and it worked!leave the car closed for 15 minutes
Sri.
After updating version 11000 I have not seen any problem messages, everything works perfectly Voice commands as handsfree calling.I updated mine now, sadly now the voice command button for some reason isn't working, says "microphone error" / check with dealer sort or error message. I think I've read something about disconnecting the battery if that's the case, anyone else have any tips?
Gone and not coming back.Where are the actual firmware upgrades downloads though?
HelloI updated mine now, sadly now the voice command button for some reason isn't working, says "microphone error" / check with dealer sort or error message. I think I've read something about disconnecting the battery if that's the case, anyone else have any tips?
what changes did you notice, do android auto maps work on the heads up now etcThanks, phew. Yea came back to try it 30 mins later and it worked!Unfortunately I had already reset the configuration to factory standard settings so got a whole lot of settings to readjust again. xD I also use Android Auto Wireless.... I had previously bought AAWireless from indiegogo that adds wireless Android Auto and it instantly started offering configuration now too and worked with the voice commands as well. (apart from certain commands gives me "routines not supported on this device" that I'd still wanna get working... but anyway that's some AA issue I'm trying to troubleshoot whenever I have some spare time...)
EDIT: I was actually on 10024 firmware (not 10042 like I wrote) before I updated to 11000 so made quite a big leap, probably at least 50 or so changes since that firmware has been added
AA/CP will not appear in the HUD, it's not supported by Mazda.what changes did you notice, do android auto maps work on the heads up now etc
I don’t believe it’s possible to install other versions as it was with the previous generation of Mazda3.Hi anyone known if this is possible with the last firmware version:
4A0* (ADR) OWNERS can install EU0* Firmware.
Thanks
What do you mean by auto update?Okay. Trying to make heads or tails of this string.
my son has a 2019 Mazda3 Select. We live in United States. He is running version 11012
When I try auto-update, it says no. But I think there is based on what I think I understand in this string
is there an update? If so, how/where do I get it? I can’t seem to find it on their website.
thanks
Auto update in settings. Over wifi. It searches and then says no newer version availableWhat do you mean by auto update?
As far as I know Mazda hasn’t pushed any OTA updates so far for any vehicle.Auto update in settings. Over wifi. It searches and then says no newer version available
Take a look at post #3 (not #4) by me over here.Ahh. That would make sense
so then back to my original question…
thanks
Take a look at the first few posts of this thread. Please read them carefully. A mistake may end up being fatal for your CMU.andrewa. Thanks. Most helpful
one last question. Are there any install notes/instructions
