hey!
Im new to working on Mazda's and thought I'd help a friend with an issue. Car runs with a lot of smoke coming out exhaust, seems to be bluish smoke. Compression tested it this morning with a cold engine and got 128/125/115/115 comp out of the cylinders. removing spark plugs cylinders 3/4 had oil all up the spark thread. Im thinking it could be a head gasket with a leak from an oil gallery into a cylinder but with two cylinders with lower compression? unsure might just have to take it apart to check head or im wondering if a stop leak product could be worth a shot 🤷‍♂️ Looking for any knowledge on these engines from Mazda gurus :)
Thanks
Were the plugs oil soaked? The Gen 1 has a bad head gasket from the factory which was redesigned. When I replaced mine, several of the fasteners on the battery side were barely finger tight. Pop off the valve cover to take a look. Only two dabs of sealant are needed where it dips. I advice using Blue Locktite for the valve cover fasteners.
Stay away from the stop leak products. Those are garbage that are used by quick-buck guys to get a vehicle to stop smoking long enough to dump it onto some unsuspecting buyer. They work by making the seals swell.
One plug was oil soaked on the tip and two others had oil all up the thread. several of your head fasteners were finger tight? Thanks I will look into this. valve cover is currently off as I was prepping to pull the head. The engine wasn't overheated as far as I know.
Yeah I didn't want to try stop leak products, the coolant looks to have no oil or contamination anyway. Yeah I'd feel shitty knowing I was selling a car with stop leak holding it together.
