1 - 12 of 12 Posts
Hello my dear friends
I have a car Mazda 6 2017 and Mazda CX7 2017 Full Option
R-BCM FOR Mazda 6 2017
;Block 1
7B701011D540006E31A
7B70102A504038008F5
7B701030030901092
;Block 2
7B702010028089850D9
;Block 3
7B7030100C2
I want to activate other features such as
enable the find my car
Or a program to modify them and activate the closed characteristics of the company
Thank you so much
· Treveloper
;Block 1
7B701011D540006E31A
7B70102A504038008F5
7B701030030901092
;Block 2
7B702010028089850D9
;Block 3
7B7030100C2
Thank you so much
Hey dude
Mazda CX-5 Service & Repair Manual - Rear Body Control Module (Rbcm) Configuration (Using As Built Data) - Data Network
but I don't think 'find my car' is a function of the RBCM but I did notice there are some serial communication and CAN system related modules that may be exploitable.
Mazda CX-5 Service & Repair Manual - Rear Body Control Module (Rbcm) Inspection - Data Network
Interesting stuff.
Hey dude
Interesting stuff.
my brother
I tried in Mazda 6 standard car 2017 and worked but did not succeed in Mazda 6 2017 full option
I downloaded a file from www.motorcraftservice.com/AsBuilt/ and the same problem did not work after editing
It also has a Mazda SkyActiv OBD-II calc (FORScan) v6.5 and also did not work with me
Do not give me his fish, but teach me how to catch them
ok i'm trying 0:)
this is only an example of the calculation on a mazda 3, I do not know if on the mazda 6 are the same bit to change
find my car is in line 7B7 01 02 bit 6 in B0.
so you have 7 B7 01 02 A5 04 03 80 08 F5.
F5 is the checksum, you have to calculate it every time there is a change in the line
A5 is B0, 04 is B1, 03 is B2, 80 is B3, 08 is B4 , F5 is the checksum.
A5 is in hexadecimal, you must convert it to binary: A5 = 10100101.
from left b0=1 b1=0 b2=1 b3=0 b4=0 b5=1 b6=0
to change b6 to 1 add 100000 + 10100101 in binary convert to hexa 40 +A5=E5
your new line is 7 B7 01 02 E5 04 03 80 08 35.
the checksum is : 7+B7+01+02+E5+04+03+80+08=35 in hexa.
I'm not sure that this is very clear but my level of English does not allow me more. :dunno:
U SALUDO COMPAÑEROS.. TENGO UN MAZDA 3 MODELO 2008 2.0L... CAMBIE EL MODULO ABS POR FALLA Y AHORA EL CARRO NO ME RECONOCE EL MODULO DE REEMPLAZO.. SOLICITO AYUDA PARA LOS DATOS CONSTRUIDOS DEL MODULO ABS DE MI VEHICULO.. AGRADEZCO SU AYUDA
[QUOTE = "Tristan-cx5, publicación: 2508862, miembro: 469202"]
Esta es la parte del foro para 2014-2018, no para 2008. Mejor inténtelo en la sección correspondiente, y en inglés.
[/ CITA]
ese es su gran aporte ???
1 - 12 of 12 Posts
