1 - 15 of 15 Posts
Mazda3 Lighting Experts
Mazda 3 Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Mazda 3's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your Mazda 3's fog lights a nice bright white that closely matches factory-equipped HID lighting! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! USA Made!
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Mazda 3).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2004-2006 Mazda 3 Hatchback
Diode Dynamics: Fog Light LEDs for 2007-2009 Mazda 3 Hatchback
Diode Dynamics: Fog Light LEDs for 2010-2016 Mazda 3 Hatchback
Diode Dynamics: Fog Light LEDs for 2004-2006 Mazda 3 Sedan
Diode Dynamics: Fog Light LEDs for 2010-2017 Mazda 3 Sedan
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
What's the latest (max lumen led) to replace the stock fog light for a 2016 MZD3 GT Sport (5k to 6k) without going to hid kit.
I drive mostly out of town (where there's no street lights), and really need max lighting at night.
Our XML2 will produce 1,420 lumens, which is plenty for the fog light location. I personally prefer 5000K, but 6000K is the most popular color temperature.
Thank you,
Nick C.
Diode Dynamics: NEW! Stage Series Light Bars
Introducing STAGE SERIES LED lighting! Inspired by the needs of a professional rally driver, these light bars have been designed for maximum functionality, with compact size, cutting-edge TIR optics, and a useful beam pattern, all in a highly durable package.
-Advanced TIR (total internal reflection) optic
-Slim design, for easy mounting
-Available in driving or wide beam patterns
Our Stage Series Light bars are available in Amber as well! Here's the Driving and Wide output comparison shots!
Thank you,
Nick C.
Discussion Starter #8
Curious to see how the new Diode Dynamics, USA-Made, SLF performs in fog light locations? (2015+ F150 shown for comparison)​
1 - 15 of 15 Posts
