1 - 12 of 12 Posts
I searched on internet for the specs and found out below. Can you please enlighten me, in tires it says R19 but in wheels it says 20-inch.
Tires: Bridgestone Potenza RE-11 235/35R19
Wheels: Rays 57 Motorsport G07FXX 20-inch Black
They should be 19x8.5 et45 up. Tires 235/35. The proven tire specs of dropped 1s w/o need of rolling fenders nor camber tweaking is 225/40/19. Diameter maybe slightly larger than stock & odo maybe a bit off, but they work.:)
So to copy the setup on the picture above. I need a R19 rims with 235/35/R19 tires? Please confirm. No additional modification?
To avoid potential rub, go 225/40/19s on 19x8.5 et45 up.....that combo requires no tweaking.:)
Hello. I suddenly changed my mind. I will go for R18 x 8. Please advise on the tire size. 225/40 or 225/45. I will plan to drop the height about 1.5" front and rear after installing the rims. Thank you master!
What offset? This dictates which of these...215-225 /45 & 235-245/40... will do.
I'm running 235/45/18 tyres and 18x8.5 et35 and dropped 1.5inch. no rubbing here.
get some coilovers to fit, arches will need rolling with this wheel and tyre fitment
Discussion Starter · #11 ·
Can you post some pictures? Thanks
1 - 12 of 12 Posts
