Hi! I have an old Mazda 3 2003. 1.6 fuel. It started jerking (back and forward), like it was cutting off fuel, on highway at about 4000 rpm. Oil was low. Since then oil + filter, fuel filter and spark plugs were replaced. If I don't release gas but keep it jerking at 4000 rpm, CEL with P0340 error comes up. It clears after a while. Driving below 4000 rpm solves the symptoms.
It doesn't happen always. I can drive all day, city / highway, different rpm without problems, then it will start jerking in the evening. Or it w stop when I go to mechanic (happened twice).
I connected to obd2 app and when it is jerking, it jerks/hiccups exactly at moment when vacuum gauge hits max (near 0). When it is not jerking, I can drive at full gas at vacuum value about 0 without problems. At idle vacuum is at about -12 value.
Vacuum hose was superficially checked. VVT solenoid was not tested (might be dirty?).
Any ideas?
Screenshot is not at time of fault. For demonstration of what I was checking out.
Sent from my SM-G965F using Tapatalk
The problem got worse after few days, hiccups occurring at lower rpm.
Actually the problem was fixed after insulating few wires around top of the engine block (below air filter & computer). It was a really troublesome thing to figure out (various dealers suggesting replacing timing chain, etc. That would cost more than a car and would not fix the problem) but luckily an easy fix thanks to a smart service guy.
