So your R&D was to move the MAF? That is some impressive work son, just don't forget to get that patented.My maf sensor location is changed, not the same distance to the throttle body as stock.
Best way to slam me is with your peak maf reading on 2nd gear.
Its very simple, a person with your e peen size can do it.
+10But you're asking for MAF readings off of one of ours cars, even though most have an intake of some type, or exhaust, or in some cases a header, and I believe you 'made your own' intake among other mods?
So wouldn't that be a major variable in your 'r&d' that would leave a lot of room for inaccurate 'testing'?
You're asking for base readings of.....what? Stock car? Slightly modified? Heavily modified? Daily driven? Tracked?
Or do these types of things not play a part in your 'research'?
Most factory ECU's are tuned to be able to deal with a very small amount of positive pressure at the intake, ie 1-2 lbs of boost, and the resultant air flow. Given the mods you've listed, I highly doubt you're getting anywhere near that.Anyone knows?
On hard acceleration I see 18.1lb/min peak (136.8 grams/sec) no CEL, gonna alter it abit more when I have time.
just wondering if the engine can take more.
Normally this would be true. But go look at his intake thread. The worth/cost was equivalent to that of a true intake, and the homemade has yet to show any type of benefit whatsoever.Most factory ECU's are tuned to be able to deal with a very small amount of positive pressure at the intake, ie 1-2 lbs of boost, and the resultant air flow. Given the mods you've listed, I highly doubt you're getting anywhere near that.
Have you been able to substantially effect the reading by moving the MAF sensor? I really don't see the air flow characteristics changing much from one end of the pipe to the other given how short it is, but if you have the means, it's worth trying. If you can trick the computer into seeing more air flow then what's actually there, or more then what it was expecting to see for a given amount of actual air flow, you may be able to trick the ECU into leaning out the mixture just a little bit. I'd be interested in hearing your results.
BTW, I don't see making your own intake as a bad thing, ingenuity and resourcefulness are worth alot more than being willing to part with your money.
Cool thread, but that is all about HP and not moving it/torque estimates....
