I just bought a jack kit on sale from O'Reilly Auto Parts for $34 (1.5 ton jack with two stands) Got it home and found that trying to get it under the front it would just barely roll under and then trying to get it under the right place and jack it up was almost impossible and a real pain. If I had a larger floor jack it wouldn't be able to fit under there at all and my 2012 isn't even lowered.
I had a couple of cheap 8' pine 1x12's in the garage so I made two 3" lift ramps, took less than an hour. I cut the boards with my skill saw at a 45 angle on the ramp part, but you really don't need to.. you could make this with just a hand saw. You could also probably use 1x8's, but I think 1x6's are two narrow to drive up onto easily.
These work great, very easy to drive up onto them and you can feel the stops. Just rising the front 3" now makes it a breeze to get the floor jack under there and I can now easily see where to jack it up so I can put the stands under the left and right side in their support pinch indents.
Hope this is of some use to some of you as I've seen other posts about having trouble jacking up the front. I saw another thread where some one did a similar thing using 2x8s, but he was trying to actually make car ramps. Mine are simply to help jack up the car if you have a floor jack; they are cheap, light weight and don't take up much storage room.
