Hi,
I have a 2008 Mazda 3 Sport (Hatchback) in UK.
The right hand side (driver side) low beam stopped working.
I changed the bulb and checked the fuse but it is still not working.
Any help would be appriciated,
Thanks
Hi!
Probably your ballast is completely dead...
In that case you'll need to find the same model for your car at your dealer (if you use OEM Ballasts) or find a new kit to match the other beam
Hi Just curious if this worked. My 2005 Mazda 3 Hatchback has the same issue with the low beam on the right side. I noticed that moisture builds up inside the whole compartment. Any advice will be great. I have the Xenon Lights
