Hi guys, I need some help. My gf has a 08 Mazda 3 2.0 AT. Has 300,000km on it. We had a engine light come on and the codes indicated bank 1 sensor 1 O2 sensor. So we ordered a O2 sensor via ebay special and installed it. The code never went away, and I didn't have the OBD code reader to follow up. I recently went out and bought one after her car backfired through the intake, and it these codes...
p2177 system too lean off idle bank 1
p2187 system too lean off idle bank 1
p2097 post catalyst fuel trim system too rich bank 1
p0131 O2 circuit low voltage bank 1 sensor 1
p0132 O2 circuit high voltage bank 1 sensor 1
p0134 O2 circuit no activity detected bank 1 sensor 1
p2195 O2 sensor signal stuck lean bank 1 sensor 1
p2237 O2 sensor positive current control circuit/open bank 1 sensor 1
p2251 O2 sensor negative current
p2177 pending system too lean off idle bank 1
I cleared everything and went for a quick drive and checked again, these codes showed up as pending;
p2187 system too lean at idle bank 1
p2251 O2 sensor negative current control circuit open bank 1 sensor 1.
To add to everything shes got something up with her exhaust, at first I though it was a cracked header but I couldn't feel any air leaking around the header so I think the resonator has failed - her car sounds like a tank all the time.
I've ordered a new NTK O2 sensor and resonator from RockAuto, but looking to see if there's any other ideas or suggestions.
Thanks.
Thanks.
