Success! Powered sub added to Bose system on Turbo Sedan with no factory wires cut.
Well, mostly a success. I started having problems last night with the sensors and onboard computers. Luckily, after spending the better part of this morning staring at a reccurring message on the dash that read "Engine Malfunction. Please bring your car in for service." Even after repeatedly disconnecting the negative battery terminal and waiting 3+ minutes. Also no signal from the LOC to sub after a really loud electrical buzz yesterday that sounded like I blew a fuse.
Things were looking really bad.
Then things started coming together. The engine eventually reset on its own. No idea how. The sub finally came to life after I realized I had to T-splice both channels, so 4 leads, from the Kicker 46KISLOC2 into the 2 front door speaker loops created with this connector from the AmpPro PAC:
The male side goes into the RIGHT most plug on the back of the Bose amp. The female side of the AmpPro plugs into the connector that you unplugged from the Bose. For these 2 I had to use some large clamp pliers because they were REALLY hard to snap together by hand.
Leave the wires marked "Subwoofer" as sealed dead-ends on BOTH the long and short ends. I spent way too long stupidly trying to use these leads. Leaving them disconnected will leave the factory Bose sub deactivated.
Then connect the 2 whites to the 2 corresponding whites and the 2 grays to the 2 corresponding grays. This closes the connection to the 2 front (non-cowl) door speakers, allowing the Bose to power them.
Then (or rather at the same time) somehow T-splice your 4 leads from your 2 channel LOC into those 2 closed loops from the adapter. It looked a little messy at first. I used heat crimps, but the hair dryer didn't do much so I just left them unheated for now. This was pre-organization:
Then after some careful placement:
It's more or less a standard LOC hookup, only you're doing it on the harness and not onto any factory wiring. Here's a down and dirty diagram:
Depending on your connectors, what I did was crimp the connector end with a single wire in it first, then the end with 2 wires inserted in it second. I don't think a single crimp in the middle would have worked with these connectors.
With the seat bolted back in place, the amp cover back on, and the Kicker LOC stuck on top of the cover:
Final location in trunk:
Phase set to 0. Crossover at 80. Gain right at 50% for now. I drained my battery at one point and had to jump start the car. I'm guessing that listening with the car in accessory mode might not be a good idea.
All systems seem to be back in working order this evening. Well, all but 1. Remote Start stopped working. I have no clue where to start with that, but given that I thought I had possibly destroyed a 30k car this morning, I'll take it.
