I recently bought a 2012 Mazda3 i Touring Hatchback, first time Mazda owner.
I took out the amp and sub out of my old car and went and started installing it in the Mazda3, but ran into a problem.
My amp isnt turning on...
Using a multimeter at the amp's terminal, i found out that not enough voltage is going into the remote terminal. (meter read it at around 6 volts)
The 12v terminal at amp reads at +12 like normal
I have continuity on the ground wire.
Using a LOC. i tapped into the wires of the factory wiring harness of the radio.
The LOC has 7 wires:
Yellow = +12v (Tapped into light blue wire in factory harness, suppose to be 12v accessory wire)
Black = ground (Screwed it right to the metal surface of radio)
Blue = Remote wire (Ran into the amp)
White = + left speaker
Wht/Blk = - left speaker
Grey = + right speaker
Gry/Blk = - right speaker
I used the multimeter on the light blue wire on the harness, and it also reading at 6 volts.???
I tested all other wires in the harness, and found no wires giving +12 volts, but if i plug the radio in, it works fine....
Has anyone ran into this problem?
Am I tapping into a wrong wire?
