Just as the title says. Any of my 2013 mazda 3 guys or gals replace your headlight bulbs with the H11 LED bulb?
Thanks
yep. ordered one set of low beams and a set of fogs. all led from ebay. fogs were around $10 and headlights around $25. super easy to install and upgrade the look of the car drastically.
both low beam and fogs are h11 bulbs. I think the high beams are 9005 or something like that though.
little tip. if you are replacing you fogs, dont go through the splashguard or fender (wayyyy to much work) super simple just pull on the top inside corner of the plastic foglight bezel and they pop out revealing just the foglight which is held in by 3 Phillips screws. just take those out and pop in your new bulb.
Did mine about a month ago, no regrets.
Had HID for a couple of years but the ballast let go.
the light discharge and color are the same as the HID but there isn't that annoying warming up phase with the LEDs
got mine off of ebay - NIGHTEYE H11 LED Headlight 50W
I just did my low beams, Idon't have fogs. I would like to do the high/DRL lights but LEDs would not work.
