Thought I would try this out and see how it looks.. so far, some issues, fitment etc.. we will just have to see. Drivers side is just setting there for reference
I should hopefully finish it up today and will leave some photos of the work and operation for anyone who would like to know moreCan you leave a link for those LED lights? Interested to know how the grill will glow at night
If you have the blank spot covers in the center console storage for USB/AUX/ETC., you could put it there. That way you have a cheap parts to modify. That is where I put my sub level control, but I have a '17 and those have USB and AUX where your year CD player would be. It is cumbersome, but for lights like that it isn't much of an issue.I have not wired up the lights yet but I got a pretty slick push button for them, not sure yet where to mount it and reluctant to drill the hole without being sure. I will post a picture at night. Mind not the dirty car...
Been trying to figure out how to wire to fogs but the fuse I tap into doesnt activate the item I was trying to turn on.If you have the blank spot covers in the center console storage for USB/AUX/ETC., you could put it there. That way you have a cheap parts to modify. That is where I put my sub level control, but I have a '17 and those have USB and AUX where your year CD player would be. It is cumbersome, but for lights like that it isn't much of an issue.
There is wiring it to your fogs and just using the stalk controls.
I can't say for sure, but the switch for the Fog lights are probably after the fuse then. Try tapping into the wires closer to the fog lights. This should help.Been trying to figure out how to wire to fogs but the fuse I tap into doesnt activate the item I was trying to turn on.
These look awesome!As promised
The stalk controls a ground through the FBCM. You have to tap into the fog light harness ground. What I did for my light bar was to find the same connector mazda used for the fog lights and it just plugs in and works but I don't have fogs('17 and my light bar is better than the dinky stock fogs we get in '17+). I would assume the stock fog fuse can't handle the load of the fogs and the lights you added, so I would use a relay off the ground for the fogs which gives a ground to the grill lights and fuse those separately. Using the same connector on a male to female pigtail would allow you to not permanently modify the stock harness but by all means just tap it appropriately.Been trying to figure out how to wire to fogs but the fuse I tap into doesnt activate the item I was trying to turn on.
