I have a 2012 Mazda 3 HB, Skyactive.
As recommended, I purchased a 3rd FOB in case one of the originals got lost- I programmed the FOB to unlock/lock the doors. The dealer cut the key and then I programmed the key- all without any problems.
Then one of the original FOBS was lost. So I purchased another. I went through the same scenario, but this time the key will not program. The engine immobiizer light flashes when no key is in the ignition. The car does start with the older FOBS.
Does anyone have a solution to deactivate the engine immobilizer light and if this could be causing the new FOB key from programming?
I have read of similar issues and recommending removing the negative battery cable, but I seem to remember reading that doing so could then cause the windows to not go up and down completely, so I thought I would ask about this specific issue.
Thanks in advance.
Reading that statement you aren't being clear? Did you ever start the car with the first "new" key?
I did as you did and bought another key off of eBay before any of the two keys I got disappeared.
I had the "new" key cut at the dealer and while they watched and snickered; I programed the car to acknowledged the key and the remote functions.
They wanted 260.00 to do it - key and programing.
What I found out is there are two separate programing procedures to follow; one is to have the car acknowledge the key and allow it t be started. You have to run ALL three keys through the procedure before terminating it.
I then tried to start the car with each key and the car started.
NOW I have to go through another programing procedure to have the car acknowledge the "remote" functions on ALL THREE KEYS.. When that was done I tried the remote on all three keys and it worked.
While the morons at the Mazda dealer were watching and no longer snickering I drove off..
Programing just the key to start the car:
Items needed:
1. 2 pre-programmed transponder keys.
2. 1 new transponder key
The timing is critical to this procedure, please read through the entire procedure before attempting.
Procedure:
1. Insert one of the pre-programmed transponder keys and turn the ignition to "on", leave on for at least one second (I wait until the red key symbol in the instrument cluster extinguishes), remove the key from the ignition.
2. Within 5 seconds insert the second pre-programmed key and urn the ignition to "on" for at least one second but no more than 5 seconds (use the key symbol for this as well) then remove the second key.
3. within 10 seconds insert the new key in the ignition and turn the ignition to "on", if you are successful the red key symbol will illuminate then extinguish after about a second.
If you are not successful the red key symbol will flash repeatedly to indicate that you have inserted an invalid key. Remove the key, wait a minute and try it again, it took me a few times to get it perfect and I had done it before.
How To: Reprogram Keys for Mazdaspeed3 - YouTube
Programing the remote:
1. Close all doors, open drivers door, key out of ignition.
2. Lock and Unlock the drivers door using the power lock switch on door panel.
3. Insert key into the ignition.
4. Turn key to the ON and OFF position 3 times in 10 seconds. Leave key in ignition.
5. Close and open drivers door 3 times ending with door in the open position.
6. Door locks should respond by locking and unlocking.
7. Press any button on remote 2 times. Doors should then lock and unlock.
8. If programming a second remote press any button on it 2 times and door locks should lock and unlock.
9. Remove key from ignition and locks should lock and unlock again.
