1 - 9 of 9 Posts
Aodhan Ah02 18x8.5 +35 and 18x9.5 +30
Nankang ns-25 215/40r18 for the fronts and 225/40r18 for the rears. Going to test fit the rims in the morning and take em to get mounted and balanced. The cars already on Raceland Ultimos with the rear perches removed for extra low.
277290
Couple of before pics for you guys
277291
277292
I’ve got a fender roller on the way. Probably won’t be able to get any rolling shots with them on until I get the fenders rolled and pulled but I’ll be updating the post with pics along the way.
Discussion Starter #2
Just tested fit the wheels. Fronts will be easy, the backs are gonna need a decent pull along with roll.
277297
277298
277299
We couldn’t get the back as low as it really sits on the ground so it’ll have more camber than that
Those are going to completely transform the look of your car! I'm thinking that you might have to roll and/or pull the fenders, so please follow up with photos and specifications once you get the tires mounted.
I plan on it! And I agree! Can’t wait to see them on, I’m going to get the tires mounted and balanced right now, tomorrow morning they’ll get mounted and see what kinda work the fenders are gonna need. I’ve got the heat gun and IR temp gauge on deck for the fender work, just waiting on the fender roller to come in the mail. I’ve done this before on another car but last time I used a baseball bat. It worked surprisingly well and the fenders came out great but since this set up is more aggressive I opted for the actual tool. More pics to come!
Rims and tires are on, started rolling and pulling the rear fender, going good decent lines no paint cracking. I think I’ll go a bit lower by taking out the rest of the rear sleeves and probably be adding rear camber kits.
277300
277301
Lookin' good so far. What are the specifications on the wheels and tires?
Sent from my SM-N910V using Tapatalk
Discussion Starter #7
They’re all up on the og post. 18x8.5 +35 up front 18x9.5 +30 in the rear. 215/40 and 225/40 respectively. If I had to do it again I’d go 205 up front and 215 in the back. But I will definitely be able to get these to tuck and look great with less tire stretch.
Discussion Starter #8
So a standard roll and pull of all 4 fenders didn’t do the trick. Right we’re the bumpers mount up to the wheel well can’t be widened enough. So what I did was go right to the body line of the inner fender and cut a relief behind the panel. This allowed me to manipulate where the bumper actually screws on and essentially widen the bumper along with the fenders. I got the fronts completely clearing at full lock with the coilovers completely lowered. The backs need some more width still. I’ve got a rear camber kit coming in the mail, it’ll be here Wednesday. But for now I’m gonna try doing a similar method with the back wheel wells that I did to the front. More pics to follow.
Discussion Starter #9
277334
Back on the road. Still rubs in the back a bit over bumps or with someone in the back seat but the rear camber kit gets here Wednesday and will fix that and perfect the fitment.
1 - 9 of 9 Posts
