1 - 2 of 2 Posts
I recently hooked up an amp today and got the inline converter all hooked up and turned it on too check my work and I have sound but not all power is going to sub it barely moves it and I don't know if the converter is bad or I've done something wrong I've tried two different apps same thing one amp I know works if anybody can help me I'd appreciate it thank you
are you using a line out convertor or one of the PAC interface connectors ?
My first build (sub only) I used a LOC picking up the signal from the left rear door and whilst it worked I felt it was lacking hence I moved onto install #2 (same sub and amp but the addition of a 4ch amp and all new door speakers) which iam now using a PAC interface and that was a huge improvement with the Bass how ever with no control over the system I then added an equalizer under the glove box to be able to tune the system, that system was pretty good.
Thats all been binned though and install #3 is underway.
1 - 2 of 2 Posts
