Looks like I am getting that clunk that many reported. I can easily replicate it by turning the wheel to almost full left, move forward then brake, clunk! Then keep the steering wheel at the same position, shift to reverse, move backward, clunk! at the exact moving distance without having to brake.
I checked all nuts and bolts that I had worked on to install koni/rb spring, rb front sway bar, including regreasing the bushings. Also checked steering rack bolts. The only things I didn’t check were tire rods and control arms because I didn’t touch them and the car is fairly new. This clunk happened after 2 yrs I bought the car brand new and about 20 mos after all the upgrades.
Today I installed the spring protector sleeves as strongly recommended, the clunk is still there. Thing is, I think the RB springs are fatter than stocks so the sleeves didn’t cover the coil all way and leave a good section on the outside open. My question is, what parts hit each other to cause the clunk, if this is the case. And why didn’t it happen at the beginning. I might have to use a vinyl hose instead.
Please share your ideas. I want to hear them before opening up everything again.
Thx
Thx
