41 - 60 of 60 Posts
Any method in changing FM frequncy from japanese to 88.5-108Mhz. I couldn't find a solution after searching. Can I install a different region firmware to fix this?. Thanks a lot for the great work . Learnt hell of a lot about mazda3 by going through the forum.
Sent from my SM-G9208 using Tapatalk
The issue is the TAU is region specific and even if you have the CMU firmware for a different region radio frequency spacing it won't work together.
Mazda 3 FTW
I was just wondering, has Johnson Controls (the company that makes the system) done anything to try to deter hacking the system? Any notices from them or anything?
edit: oops I though I posted in the infotainment project thread, didn't mean to post in the index thread
Johnson Controls? Not really. They changed the root password in the newer versions of the firmware, that's about it.
HOWEVER, NNG... the navigational software developer.... my recommendation is you steer clear of modifying that particular section of code.
Hi I am in Austria and I'm with Mazda 2014 I 27.00.000 I tried to update it and then shows me a Mazda logo. Everything works but I can't see anything other than the logo on Mazda. can someone help me
Did your 2014 already have a MZD connect? Or the NB1
I found on Reddit that creating the NAV card hack was deleted due to legal issues. However there was mention of the files floating around on the web. Any luck with this?
Ive found the files floating on the web. If you have valid instructions we could give this a shot.
hello, if you are on the verfion 27.00.00, it is necessary to upgrade to version 31.00.100 before moving on to another verion. The bootloop comes from the fact that you ,probaly, wanted to do a higher upgrade to the 31.00.100.
But I do not know how to help you, there is a section in the forum dedicated to the problem of bootloop.
Hi, have a CX-5 2015 with OS and FS 51.00.351 (EU) would link to install the AOI tweaks, but the AOI works on versions V55, V56, V58, AND v59.00.502- , Do anyone have an OS V55 to share. Thanks.
41 - 60 of 60 Posts
