Index for Infotainment Project
440155 Views 63 Replies 50 Participants Last post by  flyguy09
PART 1: Discussions, Info, & Access
I felt bad that I couldn't contribute much on the development side of things, so I decided to create and manage this index to help organize everything discussed in the project thread. Please understand that I am the only one managing this index. I try to update as often and with as much information as I can. Some things I ask of you:
  • Please do not post in this thread. I no longer update these posts.
  • Please refer to the main Infotainment Project Thread and similar threads for all future updates.
  • Thank you to everyone who's contributed! Not just to those whose posts I linked. Thank you to everyone who has made suggestions, contributed code, bricked their systems, uploaded files, all for the advancement of the Infotainment Project!
I. Common Discussions
  • The latest releases are mentioned below. Downloads are hard to find, as they get taken down rather quickly. I try to maintain a list of working download links in section "V. Downloads" below.
  • Android Auto and Apple CarPlay: There are a number of rumors about Android Auto and CarPlay eventually coming to Mazdas. There has been code found in the Infotainment system with the v55 release specific to these two features. However, thus far there are no concrete plans or dates set to bring these features to the Infotainment system. The last rumor was "Android Auto will be on v60 which will come out in July (2015)". Check out section "VI. Information & Resources" below for more information.
  • Text message display issues: Some people have experienced issues accessing their text messages on their phone (myself included). The general consensus is that the system can get overloaded by a lot of text messages. For me, deleting all my messages worked (I backed them all up first. Google around for an app that meets your needs to do so). Unfortunately, this seems to be the only way.
    • Also note: The system cannot view MMS - no picture or video messages
  • Other capabilities of the system: The company who developed the Infotainment System is called JCI. They were bought by a company called Viseon. Check out
    showing off the apps and other features the infotainment is capable of.
II. Installs/Tweaks
If you are serious about modifying your system, I encourage you to read the posts in the main thread thoroughly and ask questions. There are risks to altering your system, risks that could end up costing you money. Run these tweaks & scripts at your own risk. None of these are official - they are developed by users of this forum, not employees of Mazda. There is no support for them beyond the forum. Please understand that you can damage or brick your infotainment system running these tweaks. Do not attempt to make changes via SSH unless you are familiar with the process.
Before You Start:
  • Upgrade the OS - Current tweaks are designed for v51 (minimum) v55 (recommended). Attempting to tweak an older version of the system may result in serious problems for the Infotainment console.
  • If Modifying Files, Save Correctly - In Notepad++, in the Edit menu, make sure EOL Conversion is set to UNIX/OSX.
  • Understand Your Options - There are a number of tweaks available for you to run on the Infotainment system. These can be run by gaining SSH access via WiFi (requires USB script) or a USB-ethernet cable. Some tweaks do not require SSH access and manual installation and can also be run directly from script on a USB drive.
  • General Installation Instructions (Including USB Installs) - Before installing tweaks, remove the Nav SD card (if applicable) and any USB drives currently plugged into the system [source]. To install most USB tweaks, copy the files onto a formatted fat32 usb drive (Possible on both Windows & Mac OS X), plug it in to your car, turn on the car and after 20 seconds or so a window should pop up saying "tweaks applied", then remember to restart the cmu by holding BACK+MUTE+NAV. (source) Once you've done so, they should be enabled.
  • Prepare for the Worst - Generally, the worst case scenario is a boot loop. You can find instructions for recovering from a boot loop in section "IV. Troubleshooting" below.
Another resource for tweaks is the Mazda3Hacks website (mirror). Also available is a new Open MZD Connect Wiki created by user addilind. User @fitisgo has created a website that includes all of the tweaks he has personally tested with instructions.
Updating the OS
  • How to update your OS: The latest version of the OS is v55. Many people are on v29 or v33. To update the OS you can bring your car in to a dealer and claim you're having problems with something like bluetooth or screen lag and they should update your system for you. However, you can update your system yourself and it's rather easy. If you are on v29 or lower, you must update to v33 first. Once on v33, you can update to v55. To run these updates you will need the update files. I try to keep a list of working download links posted in section "V. Downloads" below.
    • OS Update outside NA: If you do not live in North America, it is possible to upgrade your OS with the North American files, however you will probably lose radio functionality (see below in "Other" section), and maybe some other features too (like weather reports).
  • Downgrading your OS: Some people have decided that they were happier on an older version. It IS possible to downgrade to an older version. First, get the OS files (located below in section V). Next, follow the steps located above for installing an update, except install the "reinstall.up" FIRST and the "failsafe.up" SECOND.
Gaining Access:
This post is split into 5 parts.
Part 1 | Part 2 | Part 3 | Part 4 | Part 5
Reactions: 5
1 - 20 of 64 Posts
PART 2: Customization & Functionality Tweaks
II. Installs/Tweaks (Continued)
Customize the Visuals:
Change the Functionality:
Play Videos:
  • Original Video Player Script: This is the first script to play a video on the infotainment screen. It allows you to load a video (.mp4 format) onto a USB drive with a script to play videos on your infotainment screen. There are no player controls (Play/Pause/Skip/Menus) and there are known glitches.
    • In v51+ you may need to run the Video Fix script. It may need to be run each time you want to watch a video.
  • There are two other video players with more functionality that are available in the "Apps" section below.
Other:
Reactions: 5
PART 3: App Development & Assorted Apps
III. Apps
If you are interested in installing an app, above all else, UPGRADE TO THE LATEST VERSION OF THE OS. Apps are most often designed for the latest OS. If you are unsure of something, it's best to ask rather than install and hope for the best. Please, read Section II above, specifically the "Before You Start" section.
If you are interested in developing your own app:
Apps are labeled in the following ways:
  • In Development: The developer of the app is still working on it.
  • Complete:: The developer of the app has finished it and is no longer working on it.
  • USB: This app can be easily installed by loading onto a USB stick with an automated install script loaded onto it.
  • NO USB: This app requires you to SSH into the system to insert the code yourself. (More risky as it requires you to be both knowledgeable and comfortable with the code.)
Below are the apps that User s have developed for the Infotainment system. I will try to keep this list as up to date as possible. Sample pictures and videos are often in the links, even if they are not mentioned here. Apps are generally developed for the most recent version. Most of the apps below are for v55, and may work for v51. PLEASE DO NOT TRY TO INSTALL ON OLDER VERSIONS. The risk of a boot loop is very high.
Reactions: 5
Thanks for keeping this updated @qbord.
Do not post in this thread. All posts will be deleted, in order to keep this organized.
The discussion is in the Infotainment Project thread.
PM @qbord for index suggestions.
Reactions: 5
PART 4: Speedometer, Video Player, and Abandoned Apps
III. Apps (Continued)
Abandoned Apps:
Reactions: 5
PART 5: Troubleshooting, Downloads, Resources, & Wishlist
IV. Troubleshooting
Something isn't working? There are always risks when modifying system files. Hopefully one of the posts linked below can help!
V. Downloads
Direct links to downloads. Please message me or reply in this thread if you have a copy of an older OS version so we can mirror it.
VIII. Wishlist
A collection of things people have asked for/about.
Like I said, anything I missed or you think should be added, PM me! I'm not very active on the forums anymore but I receive email notifications for PMs and will update as necessary. Please refer to the main Infotainment Project thread and similar threads for all future updates. Thank you to everyone who's contributed! Not just to those whose posts I linked. Thank you to everyone who has made suggestions, contributed code, bricked their systems, uploaded files, all for the advancement of the Infotainment Project!
Part 1 | Part 2 | Part 3 | Part 4 | Part 5​
Reactions: 5
Anybody can advise, how to fix the speedometer app having compass pointing to the opposite direction ? I'd installed on MZD version 56.00.240
(With navigation sd card )
Thanks
For anyone wondering if the Tweaks Master Bundle works on v55.00.760 - the latest NA version - it does!
Hello
Does this supposed to work on Mazda 2 as well ?
Essentially the hardware and the software of the infotainment system is almost the same...
Has anyone started to play with V58 on the Infotainment system.
What I would like to see:
Disable Speed Restriction
Change Background
Mute to Pause song
Change order of Audio Profile
Play Music from USB
Remove Blank Album Art
Remove Backup camera warning
Please Message me
Does anyone happen to know the latest version of the infotainment currently? Thanks!
Reactions: 1
What is the trick to get into the GPS threat which is locked for me...
Thx for any hint
Hi,
How can I access the navigation guides?
" NEW - Create a NAV SD Card - North America and Asia maps available. (USB)"
I'm trying to open the link, but it says that I don't have the permission to access it.
"mazda2skyactiv, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Thanks a lot!
Would like to take advantage of the Infotainment changes but..
I have a new 2016.5 CX-5 running:
OS version is 55.00.753 NA N (came already on the CX-5)
Music database version is 00.07.000 (I updated from 5 to 7)
Fail-Safe version is 55.00.753
There are a lot of notes spread throughout this thread and elsewhere. I'm not clear on the exact steps to take if I want to add AA or some other features. I'm not also clear if it's safe to update to 59.00.144 (latest I believe) and then try modifying. This looks like something to be careful with and I'm not finding one place with clear notes.
Anyone help? Thanks in advance.
Reactions: 1
however tweaks working on other version later than 55.00.753, but i cant find any reason to update.. as you did just updated Music database enough you have full function unit. also applying Tweaks on version 55.00.753 are absolute more safe state than later version..
so stay where you are.
Toyota Yaris iA (New owner) JCI backup
Hey I'm not sure if its possible to get the .up files from a jci backup this is running 55.00.754 NA which even has all the mazda info inside except it runs the toyota/scion boot ivf. Just trying to see if this is something I can use as a backup in case I want to go back before upgrading to 760 or downgrading to 753.
Any thoughts??
I can't post the link yet but if anyone would like the link they can message me directly and I'll gladly provide it.
Thanks for all the work you guys have done so far.
Same here, how can I access the "NEW - Create a NAV SD Card" ?
Thanks
Reactions: 1
Did you ever figure this out? I was trying to access it as well.
v59 from dealer today
I took my 2016 CX-5 into the Cranston, RI dealer today to have them update the firmware to fix the crashing issue. Got my vehicle back and it's on firmware v59. Does anybody if the existing tweaks will work with this firmware?
3
HELP! the AIO 2.1.5 made MZD bricked
AIO:2.1.5
MZD FW:56.00.513C ADR
when i installed these tweaks ↓
Text Blue Font Green Line
then the MZD FW version detected as "Not Available" and the ** USB ports became non-functional** even i did factory reset
Text Font Technology Electronic device Multimedia
so i can't restore by USB
i had found the reason in the internet ↓
Non-functional USB ports seems to have been due to a problem with libmc_user.so while installing / uninstalling media order / FLAC support patch.
I don't know why this happens, but it is not very often.
I never had this problem myself and I do uninstalling / installing all tweaks for testing nearly every day. Can't count anymore.
You have to copy the libmc_user.so using SSH and WIFI from following folder and replace the one in your system:
choose\config_org_all\media-order-patching\jci\lib\libmc_user.so.230
If you can do so, please have a look at the one on your system.
Has it same filesize?
The original one has 1.643 KB, the patched one for .230 has 2.029 KB.
Since you have FW 56.00.230 you have to take the original or patched version for 56.00.230.
Original is here:
Patched version is here:
choose\config_all\media-order-patching\jci\lib\libmc_user.so.230
You have to rename to libmc_user.so (delete .230 at the end).
If you actually have the patched libmc_user.so with 2.029KB on your system at /jci/lib folder, the I don't know, why your USB ports are non-functional atm.
but i just can't login to the MZD by SSH
Text Black Font Screenshot Technology
is there any solutions else (ex: recovery mode), plz? :crying2:
1 - 20 of 64 Posts
