Does anyone know if I can use just any deep cell battery. I was thinking of getting a yellow top optima to replace mine.
Mazda dealer says it will not work.
The EFB Q85 says 500-1000 the AGM 400-600 the EFB Q85 could fail at 500 also i talked with a few people in my town today and one of the parts guys st Mazda said it was no problem using a AGM it was actually a better battery to he EFB IS NORMALLY a cheaper battery but because you ate buying it from Mazda you are paying more he told me so it is a no brainer for me i went to Canadain Tire $220.00 can. AGM 5 year full replacement warenty costco $199.00 but didn’t have the right one!I have done additional research and have found what many have said - that AGM are better technology and are generally considered an upgrade to EFB. Great write-up here:
Which is the best replacement battery for automatic start-stop systems?
Which batteries can be used in vehicles with automatic start-stop systems? Differences between EFB and AGM technology. What is the best start stop battery?batteryworld.varta-automotive.com
HOWEVER... I also found this information here:
Flooded (Wet Cell)
Maintenance: Maintenance Required
Type: Flooded
Cycle Life: 250-500 Cycles
Duty Cycle: 50% DOD
Typical Charging Voltage: 14.4-14.5 Volts
Enhanced Flooded Battery (EFB)
Type: Sealed Lead Acid (SLA)
Cycle Life: 500-1000 Cycles
Duty Cycle: 60% DOD
Absorbent Glass Mat (AGM)
Maintenance: Maintenance-Free
Cycle Life: 400-600 Cycles
Duty Cycle: 80% DOD
Typical Charging Voltage: 14.7-14.8 Volts
The EFB has a much higher cycle life than the AGM. I also learned that the trigger for the activation of the maintenance light in the Mazda is the number of cycles the battery has been subjected to. I have no idea what that number is. If it is 500 or so, than an AGM would be fine. However, if it is upwards of 800 or so, the AGM would be subjected to many more cycles than it is capable of. What are the implications of that? Premature failure? Damage to i-eloop components?
The Q85 EFB battery is expensive for sure; over 2X the equivalent AGM battery. But I got 5 yrs and 45,000 miles from the Q85 which is a pretty solid lifespan.
Thoughts?
This is kind of a new technology for batteries, and in doing so actually puts a fair bit of stress on them. Most people have been getting the higher end batteries like the Northstar I bought and not having any problems after. To blame the whole car for a battery is kind of silly especially when batteries in general can easily be killed by a number of temperature issues.You think 5 years and 45000 k is solid not to long ago any new car’s battery would last at least 10 years! I have had my Mazda bought it new top of the line 3 model and my battery maintenance 🔋 light came on a couple of days ago 6.5 years and 90k very disappointed i call that unacceptable programmed obsolescence definitely will not purchase a Mazda replacement!
True, hence, the reason I went with a High quality Deep Cycle. The optima tops have dropped quality over the years. So going with the top of the business puts you in a battery that should never fail.The AGM was initially developed for military use, especially in airplanes where the movement of the aircraft resulted in battery liquid leaks and spills. In order to prevent this, AGM or absorbent glass mats, were placed into the battery to absorb the liquid acid and prevent spills. That and the lighter weight due to less liquid are the main plus points of AGM.
So, why is Mazda not using this type of battery for i-Stop? The main reason is that AGM batteries have a dislike for heat. Most AGM battery manufacturers recommend that the AGM battery stop charging (charging raises battery temperature) when it’s temperature reaches 49 degrees celcius!
