@sinistriel , I was waiting for you to chime-in again; you seem to have good ideas re A/T's. One of the prbs the OP faces (I believe) is the apparent intermittency of this behaviour. Will it misbehave on command?Go to the dealer and tell them you are having a "delayed engagement". This is usually indicative of a pressure issue or a combination of solenoids not allowing the Low/Reverse Brake and the one way clutch to actually operate like it is supposed to. It could also be causing the slip felt on take off.
