I did this to my 2013 Skyactiv hatch without fogs or auto lights. Vehicles with auto lights and/or foglights already installed should work the same with this mod but experiment at your own risk.
Step 1: Install foglights according to instructions provided with kit
I didnt take pics so Ill borrow a thread to show what I mean. Shout out to fellow member rope612 for the good pics.
http://mazda3revolution.com/forums/...13121-how-fog-lights-parking-lights-easy.html
Step 2: Follow his steps up until the third. Once you see the BCM, disconnect the top grey connector and look for the green wire.
Step 3: Cut the green wire about 2 inches from the connector and butt connect a piece of similar sized wire about a foot long to the end of the wire thats left sticking out of the harness(NOT the end that goes to the BCM)
Step 4: Look under the dash and find the spot thats circled in red in the pic below. Remove the bolt(10mm head) holding down that ground wire and find a ring terminal connector that will fit that bolt. Crimp that terminal onto the end of the wire previously connected to the green wire and bolt it down along with the factory ground wire.
Step 5: Make sure your added wire is out of the way of any moving parts, double check crimps and make sure to reconnect the BCM connector if you hadnt already done so. Put your trim back together and try out your lights. The foglights should now turn on with parking lamps and remain on with the headlamps.
The only downside to this mod is that the foglights will always be on when you turn on the parking lamps and also they will not turn off when the high beams are switched on. Neither of those are a problem to me but they could be fixed by adding a switch on the green/ground wire to turn off the fogs
Hopefully you guys get something out of this very poorly done how-to lol
