I tackled the install of my Corksport Short Ram Air Intake the other night. Its a very easy install.
I decided to post a "How-To" because although there is a thread on how to do a 2.5L engine, I did not see one for the SkyActive (SA) model.
I believe this install will work for other SRI's as well, if its not Corksport.
Here is what you are going to receive in the box from Corksport;
Filter (Blue, right)
MAF Housing (Black, left)
Silicone Tubing (Black, center)
Three T-Clamps (Bottom)
Before you do anything, disconnect the negative battery terminal.
Removing Stock Intake
First, make sure your MAF sensor fits in the provided MAF housing. The housing differs between the SA model and the 2.5 model. The distance between the screw holes are different. There are also aluminum pillars that raise the MAF sensor up higher on the 2.5 model MAF housing that does not allow the SA model MAF sensor to seat correctly.
To remove the MAF sensor, remove the two screws that hold it into the air box as well as the connector in between the two screws.
Once the screws are removed and the connector is disconnected, pull the MAF sensor straight up while twisting. There is a rubber o-ring that seals the MAF sensor hole that will create some friction while removing the sensor.
In this photo you can see the black o-ring.
Make sure your MAF sensor fits. Push the MAF sensor straight down into the MAF housing of the new SRI while twisting, ensuring not to pinch the o-ring. Put the screws in and make sure you can get a nice, snug fit. If it does, move on. If it does not, contact Corksport and they will help you out!
Once this is done, your going to remove another sensor that is located in the rubber tubing that goes to the throttle body. While doing this, also pull the coolant line out of the foam clip on the same tubing.
After that, you are going to loosen the two Philips head screws that clamp the rubber tubing to the throttle body and air box. I do not have a picture for this.
Once the two clamps are loosened, carefully pull the rubber tubing off of the throttle body and air box. It is rubber, so it can bend to get it off easier.
Once that is removed, you need to remove the bolt in the front of the air box. This is the only bolt holding the air box in. The first picture is the bolt, the second is zoomed out so you can see where it is in the engine bay.
Once that bolt is removed, remove the plastic intake tube located in the front of the car. There is a clip on the top and bottom of the end of this plastic tube, closest to the front grill.
Now just pull the entire air box straight up. You have to jockey it out of the area around the bracket where you took the bolt out that held the air box in. The only thing holding the air box in are two little rubber grommets under the air box that two little pegs on the bottom of the air box slide into.
Grommets
Pegs
Now you should see this...
Don't mind the red wire, that is the power source to my amplifier.
You will see a second air inlet tube. I believe this is just bringing in air from a separate location. You do not do anything with this piece.
Installing SRI
Assemble the new SRI by sliding the silicone tubing over the side of the MAF housing with the arrow that says "airflow" pointing to the silicone tubing. Use one of the larger clamps to clamp this into place. Don't tighten yet, your going to need to move it around and make sure it lines up correctly.
Place the filter over the other end of the MAF housing with the second of the large clams around the bottom of the filter. Tighten this clamp as well. The filter you won't have to twist around as much so you can snug that clamp now.
Place the last, the smallest, clamp over the other end if the silicone tubing and slide this onto the throttle body as far as you can. There is a stopper on the throttle body that will not let it go any further back. Tighten this clamp so you can twist it if necessary.
Orient the silicone tubing so the little inlet is pointing up.
Orient the MAF housing so the MAF sensor is pointing up; so you can see the screws holding it in and the connector can go straight into the port.
Once everything is oriented as stated above, tighten down firmly. You DO NOT want this to be able to twist around.
Reconnect the connection for the MAF sensor, and place the other sensor in the small inlet on the silicone tubing. Make sure this is all the way down and there are no gaps.
Once all is said and done, reconnect that negative terminal on the battery.
Turn the car on and test the intake. Listen for leaks.
If your check engine light is on, turn the car off, remove the negative battery terminal again for 3-5 minutes and then re-connect it. Turn the car on and it should be gone.
And there you have it!
Hope this helps anybody that was looking for it.
If I missed anything or need to clarify anything, please let me know.
As I said, this is my first "How-To" post.
Thanks!
Grommets
Pegs
Installing SRI
Thanks!
