I just taped my white wire and didn't connect it to anything. I do wanna double check if it dims or turns off the DRLs though, because mine are a little brighter than I'd prefer.
Yes, the white one or whatever color other than the ground and power lines are is meant to be wired to your headlights so when the low beams come on the DRLs disable. Most people just leave that part off.
I connected the white ones to my headlights before, and it dims the DRL when you turn on your headlights.
Can you explain how you did that ? Which wire is for the headlight ? I'm a novice when it comes to wiring.
Thanks
