This past weekend I installed a couple of accessories on my wife's new 3i Touring, and figured I'd take some pics and post up some How-Tos. Neither is very complicated (other is fog lights), but hopefully they can help somebody - I'll point out some mistakes I made.
The auto-dimming mirror I installed is the standard model, not the Homelink version; that being said, installation is the same. Installation was pretty simple. Here's the rundown:
Time: 15-30 minutes
Parts Included in Kit:
- new mirror
- wiring harness
- foam rubber pads
- zip ties
- wire channel
- new A-pillar tether cilp
Tools Required:
- Two small flathead screwdrivers
- Medium flathead screwdriver
- 10mm socket & ratchet
- wire cutters
- T20 Torx screwdriver or bit
- panel/trim removal tool
Note that I didn't list a torque wrench; the torque is low and I found it more of a pain than anything. I wouldn't mess with one were I to do this over.
_DSC2098 by GirchyGirchy, on Flickr
As always, with any electrical installation in your car, disconnect the ground cable from the negative terminal of the battery. This is a good practice to start and maintain. In this case, it's especially important because you're working very near an airbag!
Use a 10mm socket on a ratchet or similar tool:
_DSC2132 by GirchyGirchy, on Flickr
Begin by partially pulling out the door seal from the interior seam of the car. Simply pull down on the upper portion of seal and it easily comes down.
_DSC2032 by GirchyGirchy, on Flickr
Next, start removal of the A-pillar. It's easy to get ahold of the outer corner, but I found the inner corner impossible. I stuck my panel removal into the area shown, then pulled the trim away from the pillar, towards me, with one hand on the outer corner, the other pulling on the trim tool. It took quite a tug to get it off.
However, DO NOT pull it all the way off! I'll show why below.
_DSC2033 by GirchyGirchy, on Flickr
I'm going to interrupt now and talk about the tethered clip which attaches the A-pillar trim to the A-pillar. It has a short plastic line keeping the two together, presumably so that the trim doesn't fly into your face when the curtain airbag goes off.
So, here it is. The left part is what sticks into the hole in the A-pillar, using two hooks to keep it in. The tether is the thin plastic line coming off from it, with the little head on the end. This goes into a slot on the A-pillar trim piece. Also on the trim piece is the male part of the clip, which is the lower part in the picture. As shown in the arrow, it goes into the other part of the clip and locks into place.
You get one of these in the kit, but it's all put together. You'll need to take the two pieces apart, using two small screwdrivers to push in on each hook on the male part, so you can pull it out from the female part. These hooks are on the left and right side of it in the picture.
You won't use the new male part, it's firmly attached to the A-pillar trim. But you WILL need the female section. We'll get to that later.
_DSC2131 by GirchyGirchy, on Flickr
Ok, here we see that the trim still connected to the A-pillar itself through a tether. Circled in red is the 'head' of the tether in the trim - you can see a slot in it. The install guide said to use needle nose pliers, but I found that cumbersome. The normal flathead screwdriver worked very easily. Turn the tether 90 degrees, and push it through the slot in the trim.
_DSC2036 by GirchyGirchy, on Flickr
Afterwards it looks like this:
_DSC2037 by GirchyGirchy, on Flickr
Once free from the tether and other clips, pull it up in the direction of the arrow:
_DSC2045 by GirchyGirchy, on Flickr
Now, remove the 'female' portion of the A-pillar tethered clip from the pillar. The small screwdriver is used here - there's a small gap between the outer face and the inner clips, which you can stick a screwdriver into. Push it in at the angles shown by the arrows, and bend the tabs inward, while pulling out on the clip. See the second picture for a better look.
I was able to get one side out, then the other. If you need to ruin the clip, go ahead, as you'll be installing a new one.
_DSC2047 by GirchyGirchy, on Flickr
_DSC2055 by GirchyGirchy, on Flickr
Done with the trim for now. Remove the old mirror by unscrewing the T20 screw which holds it into the windshield mount, and sliding it up and off, opposite the direction of the arrow shown below.
New one's installed the same way. Back off the screw on the new one, slide it on, and tighten securely - but not too tight!
_DSC2062 by GirchyGirchy, on Flickr
_DSC2059 by GirchyGirchy, on Flickr
Plug in the small black connector to the front side of the mirror, with the tab facing up. It'll click into place:
_DSC2065 by GirchyGirchy, on Flickr
Next, install the trim cover which hides the wire and keeps it out of the way. It telescopes to fill the entire area between the mirror and headliner. The wider ears mount into the top of the mirror, so put the cable into the cover, leaving some slack, and push it into the mirror.
_DSC2066 by GirchyGirchy, on Flickr
While holding the lower part in, slide the upper section up, in the direction of the red arrow, and tuck the wire into the headliner.
_DSC2068 by GirchyGirchy, on Flickr
Work around the rest of the headliner to the A-pillar, tucking in the wire. I found it helpful to slide the panel tool down the edge.
_DSC2070 by GirchyGirchy, on Flickr
Tuck the wire next to the existing harness and wire tie the two together, using the taped sections of the mirror wire to protect it.
_DSC2075 by GirchyGirchy, on Flickr
Now, into the connector. Push the tab in and pull up on the existing harness connector.
_DSC2071 by GirchyGirchy, on Flickr
Snap in the connector from the new mirror pigtail harness, then do the same for the other pair; this is basically splicing into the existing wires and using their power.
_DSC2073 by GirchyGirchy, on Flickr
Foam rubber tape time! Put one strip across the two original lower connectors in that area, circled in red. I also put a second strip around the second connector of the connector which is sticking out, circled in green.
_DSC2085 by GirchyGirchy, on Flickr
Moar zipties! I put one around the Upper harness connection point and the wires on the new harness, then another around that bundle and the second smaller connection not used for the mirror. This tucked the upper harness connection in between the small unused connection and the lower mirror/OE connection.
_DSC2090 by GirchyGirchy, on Flickr
Wiring is done! Trim the zip ties and you're ready to move on.
_DSC2094 by GirchyGirchy, on Flickr
Ok, now the tethered clip. Be careful here, DON'T get ahead of yourself, or you'll have a heck of a time getting things together.
1) Take the new, female side of the clip, and rotate its tether through the slot in the existing male side clip which is still on the A-pillar trim. See picture below!
2) Once the tether's in, snap the female side of the clip onto the male side.
_DSC2096 by GirchyGirchy, on Flickr
If you screwed up and put the female part of the clip into the A-pillar without tethering it first, you'll either need to: ignore the tether; remove it and put it together in the manner above, or; yell at it and cut your fingers trying to get the tether in before resorting to removing it and starting over.
Anyway, once the entire clip is on the A-pillar trim, begin its reassembly by inserting the lower tabs into their slots in the dash, pushing down to seat it in. One of the tabs wanted to bend on me, so I had to straighten it out to get it into the tab furthest away from the driver.
When it seats fully in, move the trim piece towards the A-pillar, making sure your wiring is tucked in enough so it can snap into place.
Line up the tethered clip to its hole, and press the trim piece onto the A-pillar. I had to whack it firmly to get it to completely seat.
_DSC2097 by GirchyGirchy, on Flickr
It should be done! Reconnect the battery and test it out. Instructions on setting the compass zone are in the book, then drive around in a circle to calibrate it. It also shows how to test the dimming function.
Time: 15-30 minutes
- new mirror
- wiring harness
- foam rubber pads
- zip ties
- wire channel
Tools Required:
- wire cutters
