1. No it is not a requirement to use FL-22. You can use any Ethylene glycol coolant. However, FL-22 is a better product. It has better anti-corrosion properties and lubricates the pump better. I think a new pump costs a lot more than the coolant.2015 mazda3i AT, 110k miles (mostly hwy)
6 years and 110k miles, I think it's time for a coolant change.
1) do I have to use their FL22 coolant?
or can I use walmart brand 50/50 premixed?
2) any step by step guides?
Thx
A chemical reaction isn't very likely but is still worth considering. FL-22 is still just ethylene glycol antifreeze and water just like cheap coolant. It does have different additives in it however. The owner's manual does clearly state that you can use regular ethylene glycol coolant just fine but are the additives going to react with each other? Probably not but I doubt either of us can say for sure.I also recommend staying with FL22, as the process for switching coolant types is much more involved. Chemical reactions between different types of coolants can really screw up your cooling system.
Boy do I know all about that! I bought a '99 ford taurus as a quick flip car. While driving it home it had no heat, and the radiator fans ran continuously. When I looked in the coolant reservoir, there was lumpy black stuff floating around in it. I think someone had thrown green coolant into ford's red coolant. Double-plus un-good! Thankfully, they hadn't added enough to gum up everything completely. I did a complete flush of the coolant system. Then I reverse-flushed the heater core by alternately filling it with water, then giving it a blast of air from the compressor. Blew out black goo, big chunks of scale, and a little rust. Then I treated the whole system with Lime-a-way for a few minutes, just to dissolve a little more scale/rust. Finally I refilled with fresh coolant & distilled water. Fans ran normally and the thing would put out heat like a furnace!The one you're thinking of that reacts terribly is the old GM dexcool. In an effort to make a non toxic coolant, GM made one that uses propalyne glycol antifreeze. That stuff is quite harmless and is in fact in food we eat. It's also a shitty lubricant so they blew water pumps easily. Plus if you mix it with the traditional green stuff it'll turn into a solid gel.
I'm just wondering what idiot put dexcool into a ford. Pretty sure only GM was stupid enough to use that stuff.Boy do I know all about that! I bought a '99 ford taurus as a quick flip car. While driving it home it had no heat, and the radiator fans ran continuously. When I looked in the coolant reservoir, there was lumpy black stuff floating around in it. I think someone had thrown green coolant into ford's red coolant. Double-plus un-good! Thankfully, they hadn't added enough to gum up everything completely. I did a complete flush of the coolant system. Then I reverse-flushed the heater core by alternately filling it with water, then giving it a blast of air from the compressor. Blew out black goo, big chunks of scale, and a little rust. Then I treated the whole system with Lime-a-way for a few minutes, just to dissolve a little more scale/rust. Finally I refilled with fresh coolant & distilled water. Fans ran normally and the thing would put out heat like a furnace!
I know that doing all that to the cooling system could have damaged seals or make the heater core leak, but at that point my alternative was to replace the heater core and possibly the radiator anyway, so it seemed like a good risk. I was lucky that the cooling system wasn't irretrievably plugged up and I could clean it up. So my rule is to never mix coolants.
I buy a lot of cars, and I often find people have switched from the factory coolant to "something else" (green, orange, red, pink, blue, plaid...). Identifying what kind of coolant is in a car is often hard, as there's "old" green coolant, and "new" green coolant. Usually, if there isn't a problem with the cooling system and the coolant looks good, I leave well enough alone. But if I have to touch it, I do a complete flush and refill it with factory coolant. On the rare occasions where I can't get the factory stuff, I write what I did use on the reservoir so that the next person knows.
