For fegs that uses Turbo Timers that when the car turns off, it unlocks the car automatically.
Auto lock/unlock function
WARNING
Do not pull the inner handle on a front door:
Pulling an inner handle on a front door while the vehicle is moving is dangerous. Passengers can fall out of the vehicle if a front door accidentally opens, which could result in death or serious injury.
- When the vehicle speed exceeds 20 km/h (12 mph), all doors and the liftgate lock automatically.
- When the ignition is switched off, all doors and the liftgate unlock automatically.
These functions can also be disabled so that they do not operate.
NOTE
Additional auto lock/unlock function (Automatic transaxle)
A function setting is also available which enable automatic locking and unlocking of doors and the liftgate when shifting gears.
Refer to Personalization Features on page 10-9.
Auto lock/unlock function setting change using door-lock switch
The doors and the liftgate can set to lock or unlock automatically by selecting any one of the functions from the following list and using the driver's door-lock switch on the interior to perform the setting change as indicated in the procedure which follows.
Function Number and it's Function
1. The auto door-lock function is disabled.
2. All the doors and the liftgate lock automatically when the vehicle speed is about 20 km/h (12 mph) or more.
3. All the doors and the liftgate lock automatically when the vehicle speed is about 20 km/h (12 mph) or more. All the doors and the liftgate unlock when the ignition is switched from ON to ACC or Off.
4. (Automatic transaxle vehicles only)
When the ignition is switched ON and the shift lever is shifted from park (P) to any other gear position, all the doors and the liftgate lock automatically.
5. (Automatic transaxle vehicles only)
When the shift lever is shifted to park (P) while the ignition is switched ON, all the doors and the liftgate unlock automatically.
Programming details
1. Stop the vehicle and close all the doors.
2. Switch the ignition ON.
3. Press and hold the lock side of the driver's door-lock switch within 10 seconds of switching the ignition ON, and make sure a beep sound is heard about eight seconds afterwards.
4. Referring to the auto lock/unlock function setting list, determine the function number for the desired setting and press the unlock side of the driver's door-lock switch only in the amount of the selected function number (Ex. If you select function 2, press the unlock side of the switch only 2 times).
NOTE
There are only a total of five auto lock/unlock settings available for automatic transaxle vehicles, and three for manual transaxle vehicles. Be sure to press the unlock side of the driver's door-lock switch the correct number of times according to the selected function number. If the switch is mistakenly pressed six times on an automatic transaxle vehicle or four times on a manual transaxle, the procedure will be invalidated. If this occurs, start the procedure from the beginning.
5. Three seconds after the function setting has been changed, a beep sound will beep in the amount of the selected function number.
NOTE
- The doors cannot be locked or unlocked while the setting function is being performed.
- The procedure can be cancelled by pressing the lock side of the driver's door-lock switch.
WARNING
NOTE
Programming details
NOTE
NOTE
