1 - 7 of 7 Posts
2016 Mazda 3 GS Sedan 2.0 6AT
Hello everyone, I have a 2016 Mazda 3 and the passenger side windshield washer nozzle is kept spraying the washer fluid up to my roof. This really bothers me. Anyone know how to fix that?
Thanks.
Mazda "E" Division
Thanks.
the nozzles are in a fixed position and can't be adjusted. The drivers side could be clogged or the lines
Old German to New JDM
Not specific for this make/model but I've had some success by using a thumbtack (the type with a post, not the flat disc) and put it in the hole and try to adjust the nozzle direction that way.
Used a needle for nozzle adjustment on my '68 Volvo, no idea if sticking sharp metal piece into hole will work or not on Mazda
I just tried it today. Had a needle screwdriver in it and the nozzle is rock solid. I don't think it's adjustable in the newer model :(
Hmm, I'm gonna look at mine later. I'm thinking if you can see how is it attached maybe you can shim it somehow. Or maybe there is an issue with the nozzle?
My passenger shoots a little lower than the driver which makes sense because a large portion of the passenger windscreen is not wiped.
1 - 7 of 7 Posts
