I will say you subconsciously turned the car off without realizing it.The key fob is supposed to be in the "loop" for the ignition to operate. When I get out the car to post a letter (with key fob in pocket) the engine cuts out.
But, I've also got out and the engine has kept running, explain that one?
Sent from my Hudl 2 using Tapatalk
The engine can only stop due to i-Stop operating. Otherwise the engine will keep running until it runs out of fuel or the ignition is turned off.The key fob is supposed to be in the "loop" for the ignition to operate. When I get out the car to post a letter (with key fob in pocket) the engine cuts out.
As the Mazda employee Uncle Zen stated, it's doubtful. The key fob is only required to start the car. It would be very dangerous for the car to suddenly turn off at some point down the road...even if it is a thief. There is probably liability issues for a manufacturer if that were the case.The key fob is supposed to be in the "loop" for the ignition to operate. When I get out the car to post a letter (with key fob in pocket) the engine cuts out.
