1 - 20 of 86 Posts
Hello everyone, i am a proud owner of a new Mazda 3 2019 Hatchback Soul red crystal! Unfortunately in my country we have only 1 trim and this is the base one. It does not have the signature headlights thus the Daytime running lights are Halogen while the Headlights are led. I really hate the halogen light next to led light. How do i replace those Drls for White leds ?
What kind of bulb if it? It can't be that hard to take it out and replace it with an LED equivalent....:dunno:
Hi, you can find the procedure in the manual. You can access to the halogen by the wheel area cover opening... The LED you want is W5W Led (T10), there are a lot of options on the net... Just take care, choose one of Canbus error free type... For example: https://autoledvilagitas.hu/termekek/termek/t10-5smd-led-canbus-jegfeher
Is it just a matter of changing the bulb? Or, is the design of the reflector different as well?
So there is no way to change this ugly yellow drl to white?
Hi Savitar,
I'm in Australia as well. Our cars here use a T20 w21/5w globe. I ordered one from Stedi .com.au (
Or blingauto has a JW Speaker one or a halogen whiter If you prefer.
It's super easy to change. Takes about 5 mins each side - just unclip the clips in the wheel arch with the wheel turned.
I picked my car up today and popped the Stedi ones each side. No canbus or other errors.
edited to add link to the globes: https://www.stedi.com.au/t20-7443-w21-5w-wedge-led-light-dual-filament-parker.html
Hi Matty,
I have purchased the same bulbs from Stedi and tried to replace them yesterday, but couldn't really figure out how to do it. I took out all the "pop nails", but how did you do the screws on the bottom? I can't reach them. And do you really have to take out the whole mud protector?
Hi Matty,
Hey,
Here is a set of how to photos that someone posted over on the whirlpool forum - http://wallet-warriors.com/pix/mazda3_2019_drl.jpg
Turn the steering wheel hard right or left and pop out the little 'pop nails' and you should be able to fold the plastic back. Reach in and grab the back of the light and twist left to unlock and it should slide out. I used a glass microfibre cloth to handle the globes, something without lint and not bare hands. Then just do the reverse. The mud protector doesn't have to come off all together, just fold back. part of it goes under the metal to hold it in, so just do one side at a side so you compare to the other to make sure its back in place properly.
Shout out if you need any further help
1 - 20 of 86 Posts
