1 - 9 of 9 Posts
What's up guys this is my first post on this forum! I'm hoping that being a part of this will help me take care of my car better.
I like to listen to trap music, therefore am really into a lot of bass. I have a '15 5-door w/o Bose speakers and they're starting to make parts in my car vibrate too much and messes up the sound.
Has anyone had this problem? Also what's the best way to go about fixing it?
Thanks!
Anybody try replacing the clips in your door for new or more solid ones?
I suspect mazda damaged my clips when tinting my windows and left door panles loosely installed.
Same issue here. Driver side door handle a bit loose and will vibrate when bass is up.
Required the dealer to fixed it up during service, and they told me they tightened the screw inside the door handle.
Problem solved. Tell the dealer that the door handle is loose.
Don't know what to do with the dash though.
I replaced all of my speaker with Polk Audio, I used some sound deadening material and have absolutely no rattles.
I heard some annoying sounds today at -12 (celsius), but later in the day at the same temperature the sound was gone.
Some deadening material may be needed. Also note that 2015 models have better deadening from factory than 2014 (got a 2015 myself and it's pretty smooth), just want to make a comment on that even though TS has a 2015 (as I do).
@apme123, am interested in what you replaced with and how much work was involved? Very greatful if you can share.
1 - 9 of 9 Posts
