Thanks for this. I ended up with 5 quarts of oil before the dipstick registered full and I was under the impression that the capacity was 4.5 quarts. Out of curiosity do you know whether the clips on the oil cover need to be regularly replaced?I had this same problem after doing my first oil change. I put in the recommended 4.8 quarts. Oil level was barely at the low mark on dipstick. I asked at my local dealer about this....one of the tech's said they put in 5.2 quarts when they do an oil change. I added about a 1/2 quart. Now I'm showing a bit more than half way up the stick.
