1 - 1 of 1 Posts
2010 US Mazdaspeed 3.
I removed the glovebox per the owners manual so I only removed the glovebox ( box and door) and the center kick plate popped off as well. I did not remove the kick plate nearest the door that the main glovebox slides behind. I cannot get the glovebox back in because I can't tuck the lip of the main glovebox behind the trim piece and rubber stripping. I tried to remove the outer kick plate but it seem securely under the door sill trim.
Can someone provide info on how I can reinstall the glovebox and whether I need to remove the outer kick plate or there is a stealth way of tucking it under the lip and trim without removing all the trim around.
1 - 1 of 1 Posts
