1 - 7 of 7 Posts
Hi folks, this is my first post here. I'm working on my wife's new-to-her 2016 3 GT 6MT hatch with the factory lower body kit. The front "splitter" had come separated from the bumper (surprise?) because it's largely held together with foam tape. I was also putting in Hella Supertones and LED fogs, so I pulled the bumper off completely.
Behind the front bumper, sitting on top of the under-tray were these 2 heavy aluminum pieces. They look like clips or supports of some sort, but don't have an obvious positive-locking mechanism. The "inside" of the longer side has a rubber pad attached to it.
I'm putting the bumper back on tomorrow, so I'm hoping someone with more familiarity to these cars than I has some insight on where I should be putting these! Thanks!
Mazda "E" Division
My guess it's from the OEM bodykit and it seems like they didn't use enough adhesive glue/bolts.
I was suspecting that, but I can't match them up to anything that makes sense and will secure them.
what kind of adhesive did you use?
3M 5252VHB. I double-stacked it, though, because it was about half as thick as the original adhesive tape. I then clamped it all up overnight in a heated garage to allow it to set as well as possible.
It's worth noting that this car is a 2016. It seems that the kit changed a bit (front lip, at least) in 2017.
Reactions: MrBen
1 - 7 of 7 Posts
