tl;dr:
My display backlight failed after installing AIO tweaks, why did this happen and what do I do?
Last Sunday I installed a set of AIO tweaks, and all went well for the night. I woke up the next morning to find a dead screen, although the system was still active as it was responsive with bluetooth connection. I did the standard system reset - nothing.
I took it into the dealer for service, and they found that the backlight had failed. If a flashlight is shined on the screen, you can see the interface emitting from the LCD panel. I'm waiting for the necessary part to come in.
1. Could this be a software bug, or did the internal backlight really fail?
2. I've searched this forum up and down (plus many others), and can't find another case of this happening. Is it just an odd coincidence that the backlight burnt out right after I installed the tweaks?
3. Is there anyway to fix this before waiting for the part to come in?
The only thing I can think of that may have caused this is the boot animation. I changed it to "Car Flash", which emits a very bright white light in a strobe like pattern. I don't see this being a high possibility, but I don't know what else it could've been. I'd appreciate it if anyone else out there has any idea as to what might've happened.
