1 - 2 of 2 Posts
I already have a 4 channel amp and 4 aftermarket speakers. And I also buy a amp wire kit.
when I try to Amplifier connect to head unit, I don’t know which wire or cable I should connect.
Can somebody helps me?
What else wire or adapter should I buy? Should I also need a line out converter?
Hey!
I hope all is well for you up north (I used to work for Nortel).
Anyway, I'm in the middle of an audio upgrade project on my 2018 Mazda 3: 4-channel amp + mono-block amp + 4 speakers + 2 sub-woofers. I've already installed the PAC AOEM-MAZ2 factory compatible line output converter (LOC) and it worked great. I tested the audio output of the 4 RCAs it provides (front L/R & rear L/R) and heard good signal on each. My 3 is non-Bose. All I needed to do was connect it in-line to the factory amp behind the glove box.
Good luck!
-V
1 - 2 of 2 Posts
