1 - 20 of 49 Posts
Admiral Obvious
i would be interested, do they use the stock MS3 discs? and would OTS pads still work or would you have to run a "special sized" pad?
I believe I should be a tester and get a free kit being that Im awesome!
Reactions: sin_loki
How are these compared to stock? I'm not impressed with my stock brakes and was planning on an upgrade in the future.
Discussion Starter #7
The are 4 piston calipers and they each weigh only 7lbs a side, which shaves about 8lbs of weight on each side. This means less pad wear, and better stopping times.
Plus they come with everything you need, pads, steel brake lines, brackets, calipers. We don't have released stopping distance data yet, but stay tuned.
Admiral Obvious
are they OEM sized pads or pads of your own size?
i track and like to use carbotech pads when i do.
stupid teacha bitch!
Those are f****ng awesome. If they aren't a whole lotta dough I'm in!
Sent from AutoGuide.com App
Someone mentioned $800 but who knows
On that college budget
Not bad for new calipers, pads, lines, and all the goodies. Just need to get some slotted rotors and brake times will be gone by at least 10-15 ft. As kyle said tires help too!
Why are you guys bothering to upgrade? The stock brakes do a pretty decent job especially mazdaspeeds. Im upgrading once I hit 400whp
Reactions: warlord
Stock brakes kinda suck.. you have to be like full pedal pressed to get any kind of action out of them. I like a linear brake pedal.
Well Im talking about with upgraded lines, pads and rotors. Not upgrading the calipers
1 - 20 of 49 Posts
