I have been doing some research to determine if I could pull a small utility trailer behind a Hatchback without major problems. Mazda official statement for the US is "No". I found in Australia Mazda says "Yes".
From website: Designed specifically for Mazda3, with a factory tested 1,200kg (2645lbs) (braked)* towing capacity and 75kg (165lbs) tow ball download capacity*. The detachable tongue kit makes the tow bar invisible once removed. Comes complete with a trailer wiring harness.
Accessory Details
The trailer would only be used to haul less than 200lbs. Mostly tree branches, plywood and other items that would not fit in the hatch. I would be pulling it about 25 miles 8 times a year.
Is or has anyone pulled a trailer with the Hatchback? I would like to here your comments.
What engine size do you have 2.0L or 2.5L? I know the 2.5L would be easier.
Lastly, can anyone recommend a light weight trailer 4x6 or 5x8
Accessory Details
