1 - 8 of 8 Posts
2015 Mazda 3 SGT, 6spd MT
I'm replacing the switch for my hatch because it's worn away. Since the rear camera wiring works off the same wiring as the hatch switch, when it wears away it affects the way the camera works. Has anyone found a way to cover the switch to protect it from the weather to avoid this problem?
2018 Mazda 3 GT
I haven't seen any posts about it. Would be nice if there was an alternative material or coating you could apply.
There really should be a hatch release button for our keys too. Pretty standard feature on most cars.
On second thought, what about Plasti Dip? The malleable sealing might be enough to cover the original rubber on the switch and add an extra layer of protection.
I expect RTV silicone would be more resilient, but harder to work with. Sugru is easy to work with and it's resilient -- but I'm not sure how its adherence stands up to years of outdoor exposure.
Found Plasti Dip at Ace Hardware. Directions are simple enough, now the question is how many times do I coat it? If I really want it to be protected by elements I was thinking at least 4 or 5. Any suggestions?
I don't have experience with PlastiDip for this type of usage. I suggest putting a 2 or 3 layers on a flexible material like paper, fabric, or rubber, so you can let it cure and then assess whether it'll crack with the sort of deformation that happens with the switch. I suspect that using too thick of a coating would hasten cracking of the coating.
Discussion Starter · #8 ·
There's the Plasti Dip that was used. The labelling is misleading because the actual color is black but it makes you think its yellow on the container. It ended up being thicker than I thought, so I stuck with two coats and filled in some holes after it all dried. Feels a little different because of the rubber that is over it now, but pressing the button does not seem to be an issue at the moment. Hopefully it holds out well over time.
Wood Rectangle Floor Bumper Flooring
Automotive tire Road surface Asphalt Wood Window
Hand Drink Gesture Finger Thumb
1 - 8 of 8 Posts
