1 - 20 of 20 Posts
I am parting out my 2015 Mazda 3 touring. Please PM if interested.
Corksport short ram intake with K&N heat shield and second filter $150 (sold)
Hardrace front strut tower bar. Never used. All nuts included $100 (sold)
Plug and Play LED DRL headlights. These were $380 on ebay. I am selling them for $150 as I had to make a cut in the back cap to fit the LED headlights I used. Easy to cover up and wont be seen anyway. $150 (sold)
Hood dampers. $40
I also have Hardrace rear lower control arms and rear camber adjusters. $150 each
Reactions: stewball5523
Is headlight the plug and play? How much to ship to 02190
Yeah, i have the same ones they are plug and play 100% to the halogen models.
LED DRL's only work when headlights are on / parking lights unless you cut the brown wire and wire directly to the fuse box ( I did this, super easy) Also pull the DRL fuse or you'll have headlights on all the time. Just an FYI.
All easy to do since you have to take the bumper off anyway.
LED DRL's only work when headlights are on / parking lights unless you cut the brown wire and wire directly to the fuse box ( I did this, super easy) Also pull the DRL fuse or you'll have headlights on all the time. Just an FYI. I
Interesting. Is the DRL fuse part of the main headlight wiring?
Discussion Starter · #9 ·
FedEx ground is still pretty expensive to you. They are large boxes. About $175
No, since they are combining 2 headlights into one the high beam is triggered as if it were still a drl so pulling that fuse kust makes sure that doesnt happen. Everything else will function as it should afterward.
I sent a single oem headlight from FL to AZ for $20 in a custom made box through FedEx, if you cut everything way down you should be able to do it way cheaper. Just make sure there is no movement to protect the tabs. The original box was made to be shipped safely internationally but with the right packing we can do it much smaller and cheaper stateside.
The Adventure Mazda
Interested in the hood dampers if still available.
Discussion Starter · #16 ·
Isn't that a TheSpeedline bar? Does it interfere with taking off the brake master cylinder cap?
Never installed it so I cannot say for sure but it looks like it wouldnt be an issue.
Hey I PM'd you about the headlights. I'm interested in buying them but haven't heard back from you. Are you not able to ship to WA?
Pls let me know, thanks!
Discussion Starter · #19 ·
Hood struts are available. Just sold the intake. PM if you are interested
Discussion Starter · #20 ·
Sorry. Just sold the headlights
1 - 20 of 20 Posts
