I am still learning the ropes on driving a stick shift and my hardest point is not putting so much pressure on the pedal so I am not over-revving the engine from a stand still into 1st gear. My friend who has been helping me even noticed that it was very sensitive compared to her nissan maxima. Is there a way to stiffen the pedal so there I am not peeling out every time I start off?
I would just keep practicing, perhaps you need to let the clutch out a bit more before giving it gas?
It certainly should not be an issue once you're used to it, it is by far one of the best compact car clutch/shifters out there lol.
Practice makes perfect. Even I had a learning curve going from a regular cable throttle to the electronic throttle in these
Youre learning to drive stick and getting used to a new car so it'll take some time. Just keep practicing
Like the others have said, practice...practice...practice.
Also, taking off properly in a stick is a fine balance of both clutch AND throttle. Every car is different and this one is a little different.
I've been driving a stick for 22 years, but found starting out in first on the Mazda3 a little difficult at first.
Reactions: SneakyPete
