Yeah get the one with the short nipple and extender since the pan is recessed. The one you want is the F106S.What valve did you guys choose? I see that there are ones with long nipple which might hit the pan
Also, how has it hold up? Has it leaked? :shaun:
I went with short nipple on both cars. Long enough to attach the hose so no need for the long fumoto end. The one in the TT was just put in but I have had the one in the 3 for almost 2 years. I've had them on other cars and have never had an issue thus far.
How long does it usually take to drain? Have you had to replace the crushwasher?Yeah get the one with the short nipple and extender since the pan is recessed. The one you want is the F106S.
When they ship you the valve and all its contents, they'll give you another washer made to be used with the valve, its made of some kind of material that feels like paper but it isn't paper, I got mine during Novmeber of '14 (Holiday pack $35). Since the valve has a smaller opening it takes longer to drain the oil. It makes changing oil really easy since you can just attach the hose, place the hose into a container, turn the valve, and not be covered in splattered oil. The valves are made of brass so it shouldn't rust, they're made in Japan if that means anything to you too haha.How long does it usually take to drain? Have you had to replace the crushwasher?
ThanksWhen they ship you the valve and all its contents, they'll give you another washer made to be used with the valve, its made of some kind of material that feels like paper but it isn't paper, I got mine during Novmeber of '14 (Holiday pack $35). Since the valve has a smaller opening it takes longer to drain the oil. It makes changing oil really easy since you can just attach the hose, place the hose into a container, turn the valve, and not be covered in splattered oil. The valves are made of brass so it shouldn't rust, they're made in Japan if that means anything to you too haha.
Some people say that these valves stops the flow of sediments from coming out of the oil pan since the opening is smaller but honestly Idk about that. Some talk about rust but again its made of brass. Some people say the lever sometimes breaks off, doesn't lock properly and oil leaks, or its too hard to turn, etc. There's a lot of talk about these kind of oil changing valves and the feelings are mixed, love them or hate them. I like it since it makes oil changing a snap and plus it doesn't leave a big mess afterwards. I haven't any problems with it either since I got it November of '14.
Edit: Also some of the forum members actually run these Fumoto Valves on their cars. And I do believe in the DIY Oil Change Guide for the 2.0L cars they talk about the valve for several pages.
Yes you can use any hose as long as it fits the nipple on the valve.What type of hose do you use? One from fumoto or will any type of hosing work, as long as it fits the nipple?
